Tow car steering lock (1 Viewer)
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
Has anyone on here took the time to remove to remove the inner lock mech (the tong that engages the steering shaft) from the ignition switch.
In doing so this means you do not have to leave a key in acc position.
I do have a key with no id chip fitted but somtimes this can bring up faults on the imobiliser which means a trip to the dealers (VW UP).
I have already concidered the theft issue and being honest any body who would pinch a VW up is a real sado.
Minxy
32,659
66,565
E Yorks
Carthago Compactline
One question I'd want to know the answer to is what would your insurer say if it gets nicked ... would they pay out?
Oct 7, 2015
737
3,578
newark
Swift escape 624
If the key brings up faults are you leaving the ignition on when towing?
Doctor Dave
463
1,110
Wiltshire
None
7 years followed by a break of 11 years and then 4+ years but given up now
Something I didn't realise until I was shown the ins and outs of the workings of our A-frame job on the car. If you turn the ignition on and then off again BUT LEAVE THE KEY IN THE SWITCH then the steering stays UNLOCKED. The car is a Peugeot 107 and we have owned it since new in 2009.
Not sure if this applies to other models or other makes. We now have a key that will unlock the steering but not start the car as it has no chip in it. The car can of course be locked with another (proper) ignition key, so theft seems to be most unlikely.
Dave
Minxy
32,659
66,565
E Yorks
But what did your insurer say about the steering lock being inactive .... ????
Oct 7, 2015
737
3,578
newark
Swift escape 624
I will double check this apparently vw said it was useing a key with no program.
On mine we have to put the key to ignition on then one click back till the lights go off but the steering is still free or it will cause faults
Doctor Dave
463
1,110
Wiltshire
None
My insurer is quite happy with the car being towed on its own wheels. The steering being unlocked is the correct condition for the car to be towed in that way. The steering is only unlocked when the car is being towed, when it is parked up normal security applies.
Dave
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
All cars with a column ignition lock remain unlocked until the key is removed as long as the ignition is turned on then off.
Minxy
32,659
66,565
E Yorks
Dave
I understand what you are saying and what you do but do the insurers KNOW that in order to tow it in the way you do the steering lock is inoperable ... for example if you stopped off for a bit of shopping and left the car unattended on the 'a-frame' would it be covered if it was nicked with the steering lock disabled?
Steve and Denise
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
In all the years of driving I had never took any notice well you learn something every day(y)
Steve and Denise
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
They have possibly worked that one out for them selves but you may be right as we all know how insurance companies work.
Eg, We can not pay you out as the day ends with a Y:D:D
Steve and Denise
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
No a fiat but I use the unprogrammed key
Well that is not a VW is it, our Toyota was ok with a blank key but that is also not a VW so this key imobiliser problem could be synonomous to VW :)
Nov 2, 2014
331
295
Maldon Essex
Towbars to towcars told us turn the ignition fully on then off and leave the key in
We have a key without a chip but not had the bottle to try and start the car with it to see what happens.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Would you be surprised to learn that a missing or inoperative steering lock is an MoT fail Item
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Padlock the A frame instead. They would look silly trying to pull the van as well when backing up.
Charlie
3,211
3,639
Auto Sleeper Kemerton.
Im a newbie
All that would happen is the engine would turn over but it would not start.
Worth remembering is some cars draw current when ignition is in the off position. So long journeys or leaving a dud key in on a ferry could result in a flat battery.
I had an extra wire in the loom to ensure the battery on the toad is charged by the MH whilst on the move.
Oct 27, 2013
712
11,116
Portglenone, Northern Ireland.
Elddis Magnum185GT
Since July 2012
What's wrong with taking the key out while you go shopping? :confused: Perhaps I've missed something? Unless you mean that the steering lock has physically been altered?
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
We now have a toad with keyless ignition which is a different matter.
When we had a toad which required a key in the ignition whilst towing I would always remove the key whenever parked-up.
Minxy
32,659
66,565
E Yorks
That's what I mean ... how many remember to remove the key so that the steering lock is re-engaged whilst parked ... and them importantly remember to put it back in before towing it again!
If the steering lock has been permanently disabled though that would be a modification and the insurance company would need to be informed which, I suspect, would either mean they wouldn't insure it or add an extra premium to your policy.
I just wonder how many people have actually thought of this, that's all.
Kevan
1,097
968
Kent and south west France
van conversion
30 years caravan/motorhome
We tow a Skoda citigo, which we bought new, same as VW UP, Have been towing it for three years with key in acc position we have three sets of keys (all came with car new) two with push button fob, and one you have to lock the car by using key in lock, this is the key we use when towing, we have never had any issues, or any warning lights or message's(y)
martin ribin swinden
selby yorkshire
swift 636
5 years
you need to know the mechanical part of the steering lock is part of the mot no lock no mot it needs to work card keyless or old style its part of my job and if one is passed with it absent p45 time
icantremember
8,333
17,545
Hymer T-SL668
since 2005
Please let me know what you do with your keyless ignition as we have a Yaris with keyless but have not towed it yet.
@icantremember
It is a Peugeot 108 converted by Towbars2Towcars and has a procedure which entails pressing the start button to unlock the steering, then throwing a special switch fitted by T2T to hold the lock off.
There is a bit more to it though and sounded very complicated when we first got the car but in fact becomes very simple with practice.
Steve and Denise
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
Is this no steering lock a failier on only cars with locks fitted as standard and not like the old days of Cortinas Escorts Vivas Etc
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Don't have this problem towing our citigo :reel:
