Toothbrush Charging - will it survive? (1 Viewer)
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
You may be right. I was under the impression that the speed of the polarisation was the critical issue to stabilise the correct inductive voltage. It may be that all of the issues are factor?
From what I remember of dismantling my last dead one (not killed by any sort of inverter) is that the base is a winding over a laminated core connected directly to the incoming mains cord. The core sticks up so that it couples magnetically with the winding inside the toothbrush thus forming a (rather inefficient) transformer. Transformer-type PSUs don't like harmonics because the higher frequencies over-heat the laminations. The effect will be exacerbated by the rather (necessary) inefficient coupling of primary and secondary windings.
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
So in a Nutshell then it'll be F**ked :doh:
Steve
1,613
2,062
Compton Berkshire
C class
on and off for 40 years
had the same problem myself so now only use the psw inverter for that.
Steve
Jun 2, 2010
4,924
11,290
Flintshire
Low profile
since 2010
If your chargers fail again Domestos will do the trick:LOL:
Mar 26, 2009
8,163
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
Could it be that Sandra is brushing up and down in a square wave pattern that's what's causing the problem?:doh: Ok, before anyone tells me .......:getmecoat:
Armytwowheels
Armytwowheels
6,475
14,875
Market Harborough
Carthago S Plus - Iveco
Since 2011
Back in your box Phil, I never brush up and down! I am a Dyson girl, no loss of........ Something or other?
Oh hold on, you are talking about brushing teeth???
