tonyd (1 Viewer)
Tonyd
4
8
tamworth
B630 starline
Have recently fitted 2 bosh 110 amp leisure batteries I have also fitted a 80watt solar panel wired through the regulator then onto battery terminals.
Fitted in my motorhome Hymer B630 starline is transformer rectifier a elektroblock EBL99, can I wire from solar panel regulator into Block 6 (solar rectifier) terminals 1 and 3. Which terminals are plus and minus. When connected will this charge both leisure batteries and the vehicle battery?
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
H and welcome tony:Smile: sorry can't help with your problem but at least you will get back to the top of list:thumb:
S
stagman
I know you can connect the solar panels direct to the Sargent chargeras fitted to Autotrails but not sure about yours , have you got a wiring diagram that should help if not google it :thumb:
