Toilet water tank (2 Viewers)
mejulie
Caversham,Reading
coachbuilt
Whenever our MH is left standing for any length of time( even as little as 2 weeks), when we fill the toilet tank with water and then flush it we get this horrible black stuff coming out of it.Have tried rinsing it when its put away, and leaving it full or empty makes no difference. Any ideas?
43,330
49,446
lots of little black specs ?
its quite common and flushing doesnt clear it.
i believe Thetford do a specific cleaner for this but i dont know if it works or not.
mejulie
mejulie
Caversham,Reading
coachbuilt
Thanks pappajohn, I will investigate and post results later.:thumb:
jeffscarborough
12
Scarborough
2 years
Our last camper had a porta potty free standing loo and we put pink rinse chemical in it.
Perhaps that will work?
43,330
49,446
i had a look on the thetford site but cant find anything concerning the crud !
i think this stuff is organic, probably some form of algae, and harmless even if not very nice.
Feb 14, 2009
1,373
3,325
Chandlers Ford, Hampshire
Burstner TD700 H L
Since 2008
Toilet Flush Tank
In response to black bits from the Aqua Rinse pink flush liquid there are several responses to this at the following site
Link Removed
They seem to use alternatives to the pink or even flush out with milton or fabric conditioner ....ummmm
Lenny HB
53,440
150,044
On the coast in West Sussex
Hymer B678 DL
It's the pink stuff that causes the black bits I believe it is an algae once you have it very difficult to get rid of even if you stop using the pink stuff it keep producing.
dshague
996
302
VAN CONVERSION
20 years
have you got a water vent pipe .if you drain this out .then flush out all water .it helps get rid of black bits .i also think its the pink .
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
i can only say just like the bottom tank on our porta potty i put no chemical stuff only clean water .cant say we have any problem at all. still got some left in the bottom tank from returning to uk a month ago .that will let the good bacteria live a lovelly life .
cheers alan.
mejulie
mejulie
Caversham,Reading
coachbuilt
It would appear so, I have just purchased a bottle of Kampa Dual Nature toilet fluid. I will give that a go and post the results later.
mejulie
mejulie
Caversham,Reading
coachbuilt
Just spent a week in Cornwall and used the Kampa Dual Nature fluid. The black bits did clear up quicker than usual, smells quite nice too, but were away again in August so it'll be interesting to see if it has kept it at bay whilst standing. I'll keep you posted if any ones interested.
shedbrewer
13
St. Columb, Cornwall
VW C Class
25 years
black ''stuff'' in toilet flush,,,,
hello all, we had this problem for years, as did everyone else, recently 'in the other place', it was discussed at length and the final concensus is that, along with others, we now do not use the pink flushing liquid, but add a couple of capsful ( cap fulls ) of low price Pine disinfectant to the top tank and in the bottom, instead of ''Toilet Blue'' we use cheap fabric softener, £1 a bottle or less,,,,,, seen us OK for the last 12 months,,,,,,,,, go for it,,,, jack & petty, cornwall
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
this stuff is a cure all and says on my container it will clean out your top tank of black bits about a fiver and you only use a small amount so will last ages
http://www.fenwicks.info/fendox.htm
Dec 23, 2007
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
Try Fenwicks 'Top 'n' Tail' or 'Fendox'
mejulie
mejulie
Caversham,Reading
coachbuilt
Hello all, just back from Cornwall and great news!! Kampa dual nature toilet fluid works a treat. In fact now I only put it in the top tank and it does the job perfectly. Highly recommended!
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Biomagic, used it for 3 years since the van was new, never had any black bits in the flush.
Not cheap bur does the job. :thumb:
I never drain the flush unless I see it's going to be frosty so it never gets cleaned out in the summer, & still no Black bits.
Mixter
227
Keighley, West Yorkshire
Now a year - cant believe it!
Our van had the black bits in the flush when we got it. Id heard it was caused by the pink stuff, and thetford were selling something to counteract it. I think its a p##s take if im honest (no pun intended) ; selling you one product, then another to sort out the problems caused by the first!
I just stopped using anything at all in the tank - just clean water. After a couple of trips, the black stuff vanished and has never returned.
We tried fabric conditioner in the casette, but the mrs didnt think it eliminated odours enough. So now we are trying Fenwicks 'top n tail', but only in the casette, which seems better with the odours. For the toilet bowl, we just give it a spray of thetford anti-bacterial stuff on a regular basis.
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Thought this problem had vanished, but appears it is still around.
It is an algae it appeared first some years ago, I first came across it when I worked for Kodak and we had to change chemical formulation due to Health and Safety rules. They used to use Formaldehyde to stop algae growth but had to find something else. I think the toilet liquid makers had the same problem.
Thetford pink seemed to be the worst, but not the only one. I know at the time I went to Fiamma liquid that seemed to work.
Have since had flush from main tank and no problems.
Dave :thumb::thumb:
