Biggerthanbefore
We have a Neissmann&Bircshoff Arto 69E, Had it for a few months now and love it. Made a few changes, fixed a few bits and bobs etc.
Currently the flush on the toilet is driving me mad with it's pick and choose attitude.
We have a thetford electric flush with a c200 cassette. the flush is fed from the main tank as pressing the flush makes exactly the same motor noise as the other taps.
The previous owner fitted an independant one way valve into the main feed from the tank as the intergrated one on the pump was carp apparently. All the taps work fine once the system has been bled after first water fill with the very occaisional splutter from the hot tap in the kitchen which is not a problem to me. I am familiar with motorhome water systems andhow to fill and bleed the pipes when first filled.
The flush however works fine for a day then just stops producing water for no reason and will refuse to produce water for anything from minutes to hours or days. All the while the motor on the pump is whirring when the button is pressed and it is definatley not making the 'help I'm not in the water' noise.
all the while the regular taps are working fine.
Does anyone have any pointers please?
It will suddenly produce water when pressed after hours of not, even when nothing has changed physically from when it wasn't working.
Bodge
Bodge
