CandC
- Jan 22, 2014
- 196
- 335
- Old School :D
- Used to go with the olds! Now I have one of my own :)
Hi all, and thank you for your time reading this! I knew that there would be some work to do on a van of this age, but the list is growing I have already replaced what appeared to be the original spark plugs and HT leads and used some redex and the engine is running a lot more smoothly!
A previous owner of Charlotte, our 1986 renault trafic autosleeper RCX appears to have had some rather strange ideas. It almost seems as if he was trying to convert it back into a panel van!
At some stage, the water heater packed in so, rather than replacing it, he removed it. Ok, so I could reinstall with a replacement, but he also decided to rip out all the shower stuff from the shower room, but left the tray in. The mushroom vent where the boiler was has been capped off, but the vent above the shower is currently an open air skylight! The pipe still goes through the roof, so any water goes directly into the shower tray and out the bottom. Not an emergency, but certainly far from ideal!
Today, in Cornwall, it has been raining steadily. Nothing too unusual there, but I did notice that water was entering at the top of both the high top long windows. I've bought some high modulus sealant which states "suitable for marine applications" on the tube. Should I try to put this between the seals and the body or just squidge it round the outside of the seals? The seals themselves are in good condition with no perishing so I don't want to try taking them right out if it can be avoided!
Other issues that I have found so far are: fridge gas disconnected and fridge fuse removed from control panel, blown air gas heating clicks and whirrs but doesn't fire up, 12v system has been "modified" oh:
OK, so I'm realising that I have a few too many questions for one post LOL
I'm sure that you'll agree with me that stopping water getting in is number one priority. Any advice about resealing those top windows please? Also, is the mushroom vent / skylight *grrrr* readily available and easy to replace?
Yes, that will do for now! Thanks again for getting through this epic post. Any advice appreciated (even if I choose not to follow it all!)
Colin x
Colin x
