Ongoing trouble getting my h/brake to work on my 2007 Relay.Did the usual stuff --slacken off cables-fitted new discs/linings-adjusted linings then took up play in cables.I did notice that the handbrake itself had bent the bracket and was leaning out towards the door -looks like a design fault so welded a brace to stiffen it up. I have been pulling the h/brake on as I drive to bed linings in as well.Anything else I can try or is it a bad design as the diameter of the drum seems too small to hold a 3 ton + van .
