Temp gauge
Discussion in 'Tech/Mech General' started by nunny666, Jun 15, 2014.
  1. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    Took the motorhome out today noticed my temp gauge stayed at zero . Could this be a thermostat or sender unit , ime in a 1994 fiat hyma , thanks in advance
  2. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    Stupid phone hymer
    • Like Like x 1
  3. crimbo
    crimbo Read Only Funster
    Aug 5, 2013
    25
    8
    Hampshire
    Possibly the sender unit but I doubt its the thermostat as you would still get a reading albeit a little lower than usual. Have you checked all relevant fuses.
  4. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    Cheers will double check tomorrow , thanks for reply appreciated
  5. ramsthom
    ramsthom Funster
    Nov 23, 2011
    145
    94
    durham
    On older cars the way to check if it was the sender unit or gauge was to disconnect the lead from the sender unit, switch on ignition and touch the lead to an earth point nearby. If the gauge starts to read or goes into the red section the gauge is ok. If no reading its the sender unit or the lead to the sender unit. If the lead is ok I would think it should give 12 volts with the ignition on. Hope this helps
  6. Daedalus
    Daedalus Funster
    Nov 3, 2013
    77
    143
    North Cumbria
    Temperature guage
    Sorry, I think you've got that wrong - when you 'earth' the sender lead, if the guage immediately goes into the high (maximum) area, then the guage and lead are okay and the fault lies with the sender unit itself - no reading on the guage and it's either the guage or the lead that's gone duff.
    In my experience it's usually the sender which goes duff, but if you can do the simple check it will eliminate one or the other. A duff thermostat would normally give at least some indication of the engine temperature - if it failed in the closed position, the engine would soon overheat and show on the guage quite quickly - if it failed in the open position, it would cause the guage to read a much lower than normal reading. A zero reading, to me, indicates the probability of the sender unit having failed.
    HTH
    Daedalus
  7. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    If it's the connector in the lead or the lead how hard are they to get hold of as I don't think their a spade connector are they , thanks for everyone's replies ,
  8. yodeli
    yodeli Funster Life Member
    Oct 12, 2008
    4,414
    8,353
    Balma (next to Toulouse) France
    Nothing to do with your prob even I will watch all the answers with great interest!
    I know exactly what you mean ... mine has to deal with 2 main languages and keep mixing them up , changing the words when I think it's all settled and not for the best indeed!
    BTW you got a HYMA too on your profile LOL
    Amicalement,
    Frankie:Smile:
  9. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    Oh bludy hell lol stupid phone cheers buddy
  10. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    Can anyone point me in right direction as to where temp gauge sender unit would be on my 94 fiat ducato Hymer , can't seem to see it , thanks
  11. Daedalus
    Daedalus Funster
    Nov 3, 2013
    77
    143
    North Cumbria
    Right hand side of the engine towards the top, just above the gearbox housing. There will be rubber water pipes going to it as it's also the thermostat housing. Be aware there are two sensors on the housing, one is the temperature sender and the other is part of the cooling fan(s) switching system.
    The cooling fan sensor switch should (?) have the larger cross section and will probably have two connectors on it whereas the temperature sensor will only have one.
    HTH
    Daedalus
  12. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    That's great thanks a million buddy really appreciated
  13. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    Lol am I blind or is it hard to see as I still can't bludy find it
  14. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    Can't see anything with wires attached
    [​IMG]
  15. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    Is has wires to it but looks like some sort of stat
    [​IMG]
  16. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    Still can't find it , befining to think its been removed altogether
  17. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    Should it be located in this opening on right side of engine block ? As I can't find anything by thermostat housing ? Thanks
    [​IMG]
  18. nunny666
    nunny666
    Apr 10, 2014
    232
    41
    huddersfield
    Can someone with fiat ducato please take a picture of where their temperature sender unit is please , this is really getting to me now , thanks
  19. B-well
    B-well Funster
    Apr 19, 2008
    1,173
    924
    Kent coast
    this looks like it should be the one, if it carries water to the thermostat.
