tank cleaning? (1 Viewer)
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Hi P
Save your money
And look uo "Geo Method" Tank cleaning well worth the read and a great cheap solution I will try and find a link for you
It works really well:thumb:
I must add even though my name is Geo im in no way connected with this method, the gent has been in touch with Fun once before complaining that I hadnt made that clear enough
What is to be remembered it that before a sensor can read empty it has to be Dry ie just because you have just emptied the tank it may be a day or two before it registers empty
The main and easiest function of a sensor is to tell you when tanks are full
After using the "Geo method" my sensors were working spot on for the next two trips then it had to be done all over again
So it can be an on going job and at £14 you will soon run out of enthusiasm or cash:ROFLMAO:
Geo
LINK HERE
P
pamella
146
39
walsall, west mids
c class?
thanks Geo,
i have just read that site.i did wonder if those sorts of chemicals were worth a try.i will give it a go .
thanks again.P
P
pamella
146
39
walsall, west mids
c class?
ok i mixed 1/3 softener,1/3 bleach and 1/3 hot water with a cup of soda crystrals in a 2 litre water bottle,divided that between the three plug holes then added another 20 litres of tap hot water.
i only left it a while and the tank showed 1/4 full.i will leave it today and use the mh to do the school run the i plan on adding 25 litres at a time to check it reads the levels before i empty it all out.
thanks so far
