takin the van out of winter storage (1 Viewer)
Nov 18, 2011
11,862
43,022
Planet Earth
A van
Over 25 year's
I had to lay the van up owing to illness back in October it went today just to check it over.
It looks ok could but no damp
We lit the fire nice and cosy in no time so I started her up two cranks and she fired up as I posted the other week sticking clutch but a bit of on of and forward and backwards cleared it but another problem.
sticking front brake callipers think they will have to come off and be serviced
so think it will take abit longer to get it out of hibernation.
bill
Reactions: DBK
StanandShirley
415
491
Chatteris Cambridgeshire
Chausson Titanium 640
four years
When leaving our (Sally) Motorhome at our secure storage site Summer or Winter I leave in gear and don't put hand break on because of the brakes sticking. I do use a wheel clamp and being on the level there is no worry of her moving.
Wildbill
Nov 18, 2011
11,862
43,022
Planet Earth
A van
Over 25 year's
It is a front calliper that's sticking think I will have to take it off and service it not rely a big job normally but with my condition it all jus becomes that bit harder apart from that it just takes a bit longer
BILL
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Leaving off the handbrake will make no difference in Bill's case.
As he said it is a seized FRONT caliper.
Its a classic van, these things happen with age and the onset of corrosion to parts. No way he could have avoided it.
scotjimland
2,324
10,068
A Woosh bang
correct.. however.. it can happen with any car / van.. not just a classic..
the brake piston on my Honda CRV rear brake jammed on .. due to corrosion on the piston caused by a damaged rubber boot..
if he had inspected before lay-up he may have noticed that and serviced them..
if the pads are jammed in the calipers.. again a bit of pre - layup servicing would have prevented it..
anyways.. good luck Bill ... get it back on the road asap..
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
I guess a bit of moisture in the brake fluid won't help either. Might be worth changing the brake fluid.
Wildbill
Nov 18, 2011
11,862
43,022
Planet Earth
A van
Over 25 year's
I was quit ill when it had to be laid up I am not to worried abut doing it I should have it fixed by end of week still not 100% but getting better every day
bill
Wildbill
Nov 18, 2011
11,862
43,022
Planet Earth
A van
Over 25 year's
when water or moisture as got in to the brake fluid your rely f#'';;..d no one brake fluid shuld ever be affected with that type of contamination
it will be a bit of corrosion on the calliper pistons its only done 113000 km probably still on original pads
bill
scotjimland
2,324
10,068
A Woosh bang
bill
sorry to hear that Bill.. I'm sure you'll have her up an running soon.. :)
Wildbill
Nov 18, 2011
11,862
43,022
Planet Earth
A van
Over 25 year's
that's the nicest name I have herd it called since I got it I am touched tear to the eye:crying1:
