switches zig unit etc help!
Discussion in 'The Beginner' started by mal6186, Jun 8, 2010.
  1. mal6186
    mal6186 Read Only Funster
    May 29, 2010
    13
    just bought 93 autosleeper trident vwt4. Can anybody explain switches for electrics, pump/heating etc on the panel on wall. I am bit confused and have no instructions. There seems to be switch on tap also? Advice appreciated.
  2. ourcampersbeentrashed
    ourcampersbeentrashed Funster
    Apr 19, 2008
    7,652
    4,284
    East London
    If you could post a picture it may help as there are different zig units xxxx
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,710
    17,328
    YO11 2BD
    cant help with the control panel but the switches on the taps are micro switches and turn on the water pump when a tap is opened.......thats if they are connected..... some arent as some pumps work differently.
  4. mal6186
    May 29, 2010
    13
    zig unit confusion
    this is it - there are two switches on it and also separate control for heating
  5. Robinhood
    Robinhood Read Only Funster
    Mar 7, 2010
    159
    Sherwood Forest
  6. mal6186
    May 29, 2010
    13
    thank you for that - i'll keep searching on web for zig unit instruction
  7. Robinhood
    Mar 7, 2010
    159
    Sherwood Forest
    Can't find it at the moment, though I did find a slightly earlier Trident Manual and Wiring Diagram that might be a bit of help (previous model though :Sad:) at:
    http://wiki.club8090.co.uk/index.php/Scanned_T25_Literature_camper_manuals
    I had a '92 Trident from new, so memory very rusty but following is what I think (I take no responsibility for poor memory):
    If your 'van was fitted with a leisure battery from scratch, and I think they all were by this time (on my previous Autosleeper it was an orderable extra) then you should have a mains charger (Zig DCU3) hidden away in a cupboard somewhere. From memory this was switchable on the unit, and worked fully independently of the control panel.
    Factory-fitted water pump was pressure-switched, not micro-switched, so your tap should not be switched unless someone has altered the arrangements.
    All the 12v fuses are under the fuse flap. Without a manual/wiring diagram I couldn't say which is which. You might want to test by removing each in turn and finding out what doesn't work.
    The Fridge light indicates when the fridge is working on 12v (which it should do only when the engine is running and the switch at the fridge itself is set to 12v).
    The LH switch will be the main (leisure circuits) 12v isolator. FWIW, I believe the battery is charged either by the alternator when engine running, or mains charger when that is running, irrespective of the switch position.
    The RH switch....hm....logically this can only be the water pump switch. (but if the taps are now micro-switched by subsequent rewiring, see above, then this may have no function).
    The socket takes a 12v Din or 'Hella' plug for accessories up to 10amp.
    The water gauge is fairly self explanatory. Press the button to read the level, use the Set 'trim' (it turns) to calibrate the high point when full (only necessary once - in theory).
    HTH
  8. spotsy
    spotsy Read Only Funster
    May 29, 2010
    28
    3
    Durham
Similar Threads
  1. Bognor Saint
    9
    203
  2. Dan16
    13
    511
  3. Jasonsmall007
    6
    354
  4. Helen Morrison
    9
    284
  5. Mark Harvey
    29
    1,606
