Sump plug size (2 Viewers)
AMK
283
202
gainsborough
Coachbuild
Since 2014
Before I crawl underneath my motorhome to change the oil, does anyone know the Allen key size for a fiat ducato 3 litre engine.
43,330
49,446
should be 12mm.
Be prepared to use an extension tube on an Allan key as the bung have a knack of tightening themselves and can be extremely tight.
Better still, beg steal or borrow a breaker bar and suitable Allan key socket.....the Allan key socket will be far harder steel than a regular key.
Only use a very good quality key, which is a good tight fit, as cheaper ones will round off the corners in either the bung or the key.
I had to chisel mine out then buy a new bung as someone had used an nferior key and rounded off the bung.
43,330
49,446
just had a thought....it may not be an Allen key.
Mk3 Could be a torx bung......6 point star shape and an Allen key wont fit.
If it is torx the it may be a T50.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
No right first time John
If its an X250 it will be 12mm
Also recent topic
Broken Link Removed
