Submersible pump
Discussion in 'Tech/Mech General' started by anjer, Apr 6, 2009.
  1. anjer
    anjer Read Only Funster
    Mar 10, 2008
    9
    i'm thinking of using submersible pump in a container to fill the main tank. But in an emergency I could then use the pump in the hymer main tank. Any ideas on the type of pump (flow rate litres/min) that is suitable for a Hymer - thanks
  2. pieterv
    pieterv Read Only Funster
    Mar 8, 2009
    42
    Lichfield, UK
    My Hymer has a Reich 19l/min 1.5 bar twin pump.
    Hope that helps.
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,258
    5,239
    East Sussex 01-580-881288
    If you are thinking of an emergency pump, you would have to wire it into the auto cut off circuit otherwise it will keep running all the time.
    This is the cheapest at £9-78p
    Supply : 12V
    Cable length : 1m
    Delivery rate : Max.10L / min
    Delivery High : Max.7m (0.7 bar)
    Power consumption : 15 - 25W
    Diam : max.38mm
    Height : 120mm
    [​IMG]
    Peter
