Stregthening the bed! (2 Viewers)
Photo4x4
371
873
Scottish Highlands
Coachbuilt with over cab
Newbie
I have already spent a bit of time strengthening the bed/settee frames in our U shaped lounge (see this thread), so now I thought that I'd have a go at the end of the slatted part of the double bed that pulls out to form the double bed. This had already cracked slightly so first of all I added a couple of extra screws but I needed something to help take the weight in the middle.
After much thought I have adapted a piece of left over drain pipe! It is light and easy to pack away.
The pictures will explain all (I hope). I have little DIY talent but this was certainly an easy job that took about 10 minutes.
KH
Nov 6, 2013
1,416
3,170
S. Ayrshire
The usual
Since the beginning
Good idea !!
We have the same pull out bed, and have already broken one of the wooden cross slats. Can't find anyone who can supply a replacement slat :(
43,329
49,444
Good idea !!
A length of beechwood cut to length and sanded.
From memory they are simply stapled to the straps underneath.
Nov 6, 2013
1,416
3,170
S. Ayrshire
The usual
Since the beginning
Thanks PJ
I wasn't sure what type of wood it was.
When it happened, I contacted the usual DIY places, but none were interested. Neither were a few eBay sellers who claimed to be able to supply any size / quantity.
Feb 22, 2011
9,787
20,152
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Don't use as a trampoline is my advice
I'll get my coat then........
TheBig1
17,630
43,277
you just know it was an energetic night of passion when you have to repair the bed in the morning
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
If you need replacement slats.. it might be worth a trip to Ikea .. in their return/used section they almost always have slats for their beds.
TheBig1
17,630
43,277
Thanks PJ
theres at least half a dozen sellers on ebay with beechwood bed slats. just need cutting to size and sanding, then stapling to the web
Bailey58
8,815
29,550
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
I didn't mention it in the Bailey problem thread but now you mention it the slats on the double bed are always coming loose. They slip into plastic retainers which then push into slots in the frame but the slats are slightly too short, or the retainers too deep, and can slide too far in leaving the other end to fall out. I thought one solution may be to run a bead of mastic or silicone into each retainer to stop them moving. Can't think what the dealer would do if I asked them to sort it whilst it's still under warrant.
Chris
21,053
278,728
None
10 years
I don't have any problem with breaking beds in my van.
My 11 year old daughter sees to that:whistle:
Badknee
7,407
412,734
notloB
Vantage Neo
Living the dream.
You will have to get a book on that no touching sex, tantric I think it's called, or strong sleeping pills for your daughter. :D
TheBig1
17,630
43,277
time the daughter learnt about the freedom of a pup tent
Terry
11,932
9,082
Lincolnshire
Can't remember ;)
Thanks PJ
if you are going to Thetford I have some slats -can bring some ;)
terry
May 16, 2014
817
1,063
Ammanford
Dethleffs Trend
since May 2014
Had that problem on the Elddis. Bought some longer struts off e-bay - had to cut a little of the end but made sure they were about half an inch longer than the originals. Solved the problem.
TheBig1
17,630
43,277
i had the same issue on a previous van. temporary fix i used was to pull the sides together with a couple of ratchet straps
Bailey58
8,815
29,550
Norfolk and Toftir.
Sold
Except that the end caps, similar to these, push into a metal frame and that would take would take some pulling. :)
teknik155
204
180
irthlingborough
c class
since 2002
I could never understand why the middle slats are not stronger as that is where you kneel to climb into bed .My solution was to cut a sheet of plywood to sit on top of the slats just inside the groove .I then used one of those big hole drills to make breather holes and lighten it a bit and then cut the plywood into 4 panels. On my U lounge I have a cushion not drawers at the end and just stack the panels under the cushion.The breather holes allow you to get fingers in to pull them over into place. As I've cut two large sheets of ply under the main cushions it all levels out. The thickness of the ply depends on your weight/needs etc. This set up still allows us to pull out the slats and the number of breather holes helps keep weight down.
