Strange Gas Fault
Discussion in 'Motorhome Chat' started by Patrick, Oct 20, 2010.
  1. Patrick
    Patrick Read Only Funster
    Nov 18, 2007
    370
    10
    Liverpool
    Ok, this has me and others really baffled!:Doh:
    When we light the gas cooker rings or oven all is well, but if we then use our electric step or switch on the lights in the extractor fan over the cooker the gas goes of Why?????????
    Any ideas ??????????????????????????
    This never used to happen when we got the van, Jan used to be able to cook with the oven as we were driving
  2. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Does your cooker have a glass lid? and if you close the lid does the gas go out? if so check that there is nothing behind the glass lid when open that is pushing the lid away from the wall, even the slightest amount can turn the gas off.
    Doug...
  3. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,615
    22,792
    Narrfoook
    How weird !
    It MUST have some sort of safety device/cut off that activates if it detects a fall in battery voltage ( though lord only knows why !! )
    As a first step get the multi meter on the leisure battery and make sure it is not dropping below 12v
    Second, follow the main gas line and see if you can find a solenoid cut off.. As a temporary measure simply disconnect a wire going to it
    Ahhh.. a thought and about the only reason I can think of for a cut off.....
    I wonder if it has a widget fitted that will not allow the gas to be lit if the engine is running ? Again, can see that being a right pain in the parts but it IS a possible .. but that would take us back to option the second any way :Smile:
  4. hilldweller
    Dec 5, 2008
    27,300
    26,280
    Macclesfield
    You mean just the gas to the cooker ?
    Don't know your cooker, is it all in one ? Does whole cooker go down ?
    Some rambling thoughts.....
    There must be an electric valve in there. Why ? Safety. What would trigger it ?
    Power to this valve -- same circuit as step/fan -- fault in feed to step/fan/valve could be bad fuse contact - extra load valve drops out. Find fuse to step and see if pulling it kills cooker.
  5. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    when i read the header I thought it was going to be about baked beans:Smile:
  6. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,641
    14,316
    North Lincolnshire
    Is not having the gas on / cooking whilst on the move a touch dangerous?
  7. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    sounds like you have an LPG tank, and the valve (like mine) is and electric solenoid valve a high current draw such as a step could cause sufficient power reduction for the solenoid to drop out. are the batteries in good order, has the step been serviced lately. The solenoid can stick and needs occasional cleaning as well.
  8. hilldweller
    Dec 5, 2008
    27,300
    26,280
    Macclesfield
    He does indeed. Watched him lying in the grass trying to sort it.
  9. Patrick
    Nov 18, 2007
    370
    10
    Liverpool
    Thanks Doug,
    I will check that but doubt its the problem as it will happen to the oven even if the hob is not being used!
    Patrick
  10. Patrick
    Nov 18, 2007
    370
    10
    Liverpool
    The hob is Dometic Cramer, the oven is a separate unit and the heating does not go of when this happens to the cooking parts
  11. Patrick
    Nov 18, 2007
    370
    10
    Liverpool
    We live life that way!!!!!!!!!!:BigGrin:
  12. Patrick
    Nov 18, 2007
    370
    10
    Liverpool
    Hi Wildman,
    Yes we do have a gas tank, but the problem never seems to affect the Alda heating when this happens to the cooker……. Well I don’t think it does, or maybe just not noticed as the heating is so quiet and if it did cut of as its radiators wouldn’t notice.
    Thanks mate I will check this out!:thumb:
  13. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,641
    14,316
    North Lincolnshire
    Got to try that fast lane someday.
  14. Hycon
    Hycon Read Only Funster
    Oct 6, 2008
    91
    16
    N.E Lincolnshire
    |I belive that the gas should be turned off while on the road.I you are involved in a road traffic accident there is a possibilty of one big inferno and maybe aloud bang. Not to mention invalid insurance cover. :Eeek: Sid
