Split Charge Relay Kit (1 Viewer)
I cant remember if i asked or not but if i did humor me. As i am only running a few 12v lights, Car stereo and a couple of USB ports for charging phones would a 100amp split charge kit be OK? I even doubt i would use the USB unless driving. Wife is making noise (again) about a 12v cool box but if i get one that would be up front running from the main battery and only when driving.
I was thinking of ordering this.
http://www.ebay.co.uk/itm/Great-Val...056209?hash=item3cdab0c751:g:8BcAAOSw~1FUYSm2
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
I am just wondering what is the output of your alternator.
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
No Idea what your Idea is but if you want to charge L/Battery from the van use this kit dead simple to wire up even I can do it but don't use the Scotch locks (y)
terry
edit split relays only work while engine is running -reading your post I am not sure if this is what you want to do
Dont know i would need to look into that further. Is there a lower limit i am looking for?
terry
I was going to put in a manual switch but was put off with people saying if i forget to turn leisure off i could kill my alternator. Yeah charging on the move is what i am after.
43,331
49,461
A simple on/off switch will have no effect or your alternator.
What WILL happen when you try to start the engine is the switch and wiring will fry or, if a fuse is fitted it will simply blow.
Your starter could draw upwards of 400 amps and that would be sourced from both engine and leisure batteries which the thin interconnecting wire cannot handle.
The main reason for split charge relays only activating AFTER the engine is started.
So i will also have to remember to switch it off when i stop for fuel or a cup of tea when charging. For the sake of £40 i think i had better get the relay. I know im Scottish but not that tight. Ill presume when @Flamenca was asking about the output this would be to determine if its strong enough to charge two battery's.
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
The kit you are considering is rated at 100 amps which might well be in excess of your alternator output so I wonder why you should fit such heavy duty relays. The kit suggested by @Terry might well be adeaquate.
Ah. Penny dropped. I looked at his link and thought it was a manual system where i had to turn the big red battery switch. Just reading that advert now and found my first post that i had lost.
Oct 1, 2013
7,512
19,938
Lanzarote
Nil by mouth
Lots
I sent you a link to the one i fitted. Did you lose it, Muppet ?
Is this how Terrys link is wired in?
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
No need for the alternator wire :) simply wire to poss and neg on starter battery to the two left terminals and top right (3 on rt) to the l/Battery and make sure the L/Batt is earthed -use fuses provided ;)-it's smart and recognises that the starter battery is getting charge so simply turns on the relay (y) the two other terminals on right are for fridge etc -instructions are easy(y) -they must be even I understand them :LOL:
terry
terry
This sounds to easy :D So no switching from me whatsoever. Just plumb in and leave it to work away itself. Im liking this system more.
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
IT IS VERY EASY-- fit and forget (y)
terry
premiere99
72
31
Medomsley, County Durham
I have fitted an M-Power Intelligent Voltage Sense Relay to our Autotrail, http://www.ebay.co.uk/itm/4mtr-Spli...-Made-Leads-/251515162668?hash=item3a8f78d02c which allows both starter and habitation batteries to be charged from the alternator, solar panels or my CTEK 8 stage charger. As soon as one of the above reaches 13.3v they both benefit from the charge, when the voltage drops below 12.8v the batteries are isolated. It really is a fit and forget solution.
Cheers @premiere99 but to be honest mate this is just a throw together cheap self build van that will run for a year, might be two. If we enjoy the van then i will be buying a larger one and doing it all again but more professional. A more heavy duty split charge system may be in order. Electric hook up, kitchen. Im planning it in my head already and not even been away with this one yet.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Oh dear
You have OCD
Obsessive Campervan Disorder.
There's no cure you know, it just gets worse and worse till you buy an RV:doh:
then and only then, can you slowly downsize to a stable condition.
But alas no known cure, you can only pray you die before you go bust:rofl::Eeek:
Lol. No @Geo I only need around 9'. Enough for a bed and a kitchen unit. I think that would put me in Short wheel base Transits what should be that in the load area so add in a semi hi top and an awning with sides i would be happy at that. We mostly go to camp sights so no need for a loo. May have a rack to hang a 125/250 trail bike of the back and that would be us. When the wife gets to old i go alone :D
Feb 5, 2009
678
783
South Essex
15 in MH, 15 in Caravan
Just a thought, if I may... I bought (but haven't fitted yet) the similar "battery combiner" from Victron and I was wondering if you removed the original Autotrail split charge relay? Or did you leave it in place?
I ask as I wondered if the original split charge system might interfere with the new "voltage sensing" bit
Steve
premiere99
72
31
Steve
Steve,
I cut the blue/brown wires at the EC50 which stops the split charge, all I use the Sargent EC325 for now is a fuse box as I did not like the idea of 18V going to my solar regulator, 12v inverter or the Smartgauge box, all of which have to connected direct to the 12v battery terminals.
Feb 5, 2009
678
783
South Essex
Thank you @premiere99
I thought I should remove my original split charge, but it helps so much to hear it it from someone who has real experience...
All I have to do now is find it under the bonnet :LOL::LOL::LOL:
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
The output of the alternator is perhaps not the critical item rather the possible large inrush crrent from a fully charged starter battery into a low leisure battery
