Speed limits when towing a car (1 Viewer)
Sep 29, 2009
146
53
Heybrook Bay, Plymouth, UK
LeVoyageur 950 LVX
Always learning...
Hi all
We've recently started towing a Smart on an A frame. I know that cars that tow a trailer have different limits to normal so I thought I'd better check on the speed limits.
Our van is plated at 5 tonne (GTW 7t) so our speeds without the toad are: Built up areas: 30, Single carriageways: 50, Dual Carriageways: 60, Motorways: 70
However I can't see any reference to a motorhome towing a car. Anyone know if it is any different?
Cheers
Andy
Aug 18, 2014
23,839
134,260
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Yes you come under trailer rules.
  • 30mph limit applies on all roads with street lighting unless signs show otherwise.
  • 50mph applies on single carriageways unless signs show otherwise.
  • 60mph applies on dual carriageways and motorways.
It should be remembered that you must not travel in the right-hand lane of a motorway, with three lanes or more, if you are driving a vehicle drawing a trailer.
AndyJJDavies
Sep 29, 2009
146
53
LeVoyageur 950 LVX
Always learning...
Thanks, that was the bit that I was missing. (y)
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Watch out for tailgaters!
DanielFord
3,020
3,086
Doesn't the heavy vehicle towing limit of 50/50/60 apply in this scenario?
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
No because the speed limits were changed. Dual carraigeway is 56 mph and single carriageway is 50, providing there's no lower speed limit in force.
Totally correct about outside lane. No using if towing but remember, outside lane over 2 lane motorways.
It's worth noting, because a lot of people forget, about dual and single carriageways. Irrespective of how many lanes in each direction, it only becomes a dual carraigeway if there is a PHYSICAL separation.
Nov 6, 2013
1,416
3,171
S. Ayrshire
The usual
Since the beginning
That's correct
Then when you're towing: 30, Single carriageways: 50, Dual Carriageways: 60, Motorways: 60
And stay out of lane 3 (or 4) / outside lane
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
That's correct
Technically those are correct for HGV too but HGV have limiters fitted and those must be set at 56.
jnn
250
684
cheshire
van conversion trafic
nooby
what's the van limit on dual carriage way with a 60 limit rather than national speed limit?
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Any road that has a speed limit in place is the maximum speed for that dual carraigeway. There are dual carraigeways with a 30 maximum so the speed limit is 30.
Incidentally, 30 is the only speed limit that doesn't require repeater signs other than National speed limit. So any road you are on, assume it's 30 unless you pass a repeater sign at a higher or lower limit
jnn
250
684
cheshire
nooby
Oh I know, but if it was national speed limit single carriage way the van (goods vehicle) limit woudl be 50, if it's a normal (70) dual carriage way the van limit would be 60, so bit unsure, and it's at the end of my road. Currently sticking to 50 to be sure
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
That's fine.
PeteH
6,853
9,032
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
That too is my understanding, Unless something has changed in the last few years?
43,357
49,636
Exactly......
People mistakenly think it's a dual carriageway as there are usually two lanes in each direction.
A road can have the above but without the divider, be it grass, a hedge or a barrier, it is a two lane road and speed limits apply as if it were a single lane each way.
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
I understand that in Spain you can drive at any speed you like when towing a car on an a-frame :whistle:
11,957
16,572
Why worry - there are no Police and cameras can't differentiate towing / not towing. I have always towed (not caravans) at solo speed limits. (What few) Police (there are) ignore it unless you are daft enough to use the outside lane (where more than two are available). I'm with Terry&Pauline.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
No officer that is not a trailer, it is a tailgater driving too close, he made a runner when he saw you.
