Spare wheel help
Discussion in 'Tech/Mech General' started by Microchip, Mar 9, 2014.
  1. Microchip
    Microchip Funster
    Apr 8, 2012
    131
    123
    Hampshire
    I don't fancy having a puncture on the van and repairing it with that goo that's supplied, so I bought a new spare wheel but don't want to carry it in the garage.
    I prefer to fit the spare under neath on the chassis but not behind the back axel because the grey waste is fitted there :Doh:
    Just wondering has anybody had an aftermarket carrier fitted forward of the back axel and where did you get it from.. :RollEyes:
    Thanks in advance, :thumb:
    Keith
  2. phil1946
    phil1946 Funster
    Apr 21, 2009
    265
    3,116
    South coast of England
    I wanted ours out of site and everybody told me it could not be done:Smile:
    I ended up using a pair of those threaded hooks that folk use to keep ladders attached to roof rails (bought from Screwfix). I found a place where I could hook these to the chassis and then passed the threads through the wheel and just screwed the wheel up out of the way tight to the bottom of the vehicle.
    I also fitted a safety / anti theft chain and padlock.
    Only problem is that, while the wheel can be easily dropped in the event of a puncture, it was difficult to get the threads through the wheel at home (with trolley jack and packing bits) so I would have to find somewhere else to put the flat.
    • Like Like x 1
  3. mentaliss
    mentaliss
    Nov 2, 2012
    657
    307
    Lancing
    Bought mine eighteen months ago from Ebay source (latest type) earlier version's for Ducato failed..you can look at Techno's thread where he fitted his to his Rapido (ALko Chassis) if your chassis ( I presume Fiat) is low line or heavy duty the device should bolt up to the central cross member of the chassis, beware though most of these units fit after the back axle for correct weight distribution:Cool:
    • Like Like x 1
  4. Geordies
    Geordies Funster
    May 29, 2013
    957
    2,192
    Tyneside
    I may be wrong here, but if fitting a device to carry a spare wheel and it had to go under the MH, would the best place for weight distribution not be between the axles somewhere ?
  5. SuperMike
    SuperMike Funster
    Apr 28, 2010
    1,013
    1,133
    St Albans
    Fitted up underneath, can you get it out with a flat tyre. Please don't tell me you would first jack up , then roll under to get it out. :Doh:
  6. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,140
    15,091
    Leeds the one up North
    • Like Like x 1
  7. Steve304
    Steve304 Read Only Funster
    Nov 29, 2012
    39
    7
    Wigan
  8. phil1946
    phil1946 Funster
    Apr 21, 2009
    265
    3,116
    "Fitted up underneath, can you get it out with a flat tyre. Please don't tell me you would first jack up , then roll under to get it out." :Doh:
    Thought of that, RV has twin rears so unlikely to be lower at back and a flat front would give me more room not less.
    Spare is close enough to side of vehicle that I would not have to get under AND I have hydraulic leveling jacks and wood packing if needed.
    Thanks for your thoughts, and good warning to others, o super one.
    Hope to meet you and the management again one day.
  9. Techno
    Jul 28, 2010
    14,140
    15,091
    Manufacturers would not be interested due to payload constraints which is why they stopped providing spares more than the cost saving
    • Like Like x 1
  10. Castaway
    Castaway Funster
    Mar 2, 2008
    177
    39
    Darlington
    I did the opposite thing and moved my spare wheel from under the chassis at the rear into the garage. I now have a permanently clean spare and no worries about access in the event of a rear puncture! :Smile:
  11. mentaliss
    mentaliss
    Nov 2, 2012
    657
    307
    Lancing
    Yes absolutely, and on my Dethleffs low Fiat chassis there are two central chassis cross member's that are not obstructed, either member would allow the lift device to be fitted the only problem is the pre-drilled holes do not have any captured nut's in them so it requires me to fit rivet nuts or weld in nuts first so for this trip the wheel stays where I put it:Laughing:
    PS, on a vehicle that's over 7.2 mtrs long + a bike rack with the garage overhang off the rear axle and any one singularly weight such as a heavy wheel within a loaded garage could mean spring rebound.....so June-July the air spring assisters should keep that under control:Smile:
    Ebay : FIAT DUCATO WHEEL CARRIER current bid £40.00
