Spare wheel - 202 (1 Viewer)
Chriszuki
4
Solihull
Hasnt arrived yet
Newbie
Hi anybody know if its poss to mount the spare wheel underneath instead of on the watdrobe? ( we dont get our van till march so cant check yet)
Thnks
Feb 14, 2009
1,373
3,325
Chandlers Ford, Hampshire
Burstner TD700 H L
Since 2008
No its not possible - the spacing of the chassis framework does not allow a tyre to fit in between and anywhere else a tyre would be too exposed and close to the ground.
Brimal
113
164
Drayton, Norwich, Norfolk
Low Profile
Many years towing and Moho since 2004, presently Adria Coral 690SP Platinum.
Thnks
Yes depending on the make of Motorhome and how the conversion was done. Have a look on ebay, 'ducato spare wheel carrier' always some of varying prices and condition. She Sevel vans have fittings for these behind the rear axle.
Brimal
113
164
Low Profile
Sorry that last sentence should have read "The Sevel vans normally have fittings for the spare behind the rear axle"
Steve N Tracy
1,235
3,728
Southampton
4 Years
There is a bit of space forward of the rear axle that is nearly big enough but you would have to store the wheel almost deflated to get it in.
I would have liked to move mine from the lower wardrobe to gain more space, I did move the tool kit to the gas locker to gain some space.
Unfortunately the waste tank occupies the normal spare mounting area.
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Ours is a Ducato base and our spare wheel is under the rear access
Jul 29, 2013
9,071
18,539
Salisbury
Hymer B678DL A class
since 2011
Not quite correct see @Techno he built his own carrier it depends what chassis you have(y)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
clearly :LOL:
Techno
Jul 28, 2010
15,475
20,756
May 2010
Perhaps clarification of the significance of "202" might help? I've not a scoobie do
Jul 29, 2013
9,071
18,539
Salisbury
since 2011
There's always the option of fitting it on the back either on a Towbar mount or directly to rear panel,might be helpful if @Chriszuki responded.
C
Chriszuki
4
Solihull
Hasnt arrived yet
Newbie
Thanks 4 the replies, (yep posted this in the "Benimar" section so didnt elaborate on make.)
Ive got a Ducato panel van for work and the spare is under the floor so was hoping it could go there for the MH, but ive looked at the chassis and its a ladder style so with tanks etc there may not be enough room. we dont get the MH til march 17 so will investigate further then
LouandCarol
North Yorkshire
Autotrail 620
2 years
Chriszuki
We are just in the process of changing to a Benimar 202 from Autotrail 620 and just seen this problem with no spare wheel carrier fitted. Given the already ‘tight’ storage provision this could be a real problem.
Did you find any method of storage outside the motorhome which is suitable?
Jun 25, 2016
181
338
Ynys Môn, UK
2016 Benimar 243
Since 2016
Can be done, this is from the Benimar UK owners Facebook pages, apparently just bolted through rear wall.
LouandCarol
North Yorkshire
Autotrail 620
2 years
Thanks Ratcatcher?
We’re going to give a few trips and see how it goes.
I’ve got a Fiamma back box as well so that’ll help.
