Spanish Repsol Gas Bottle (1 Viewer)
Aug 19, 2010
340
354
trawden lancs
Getting ready for our trip on Tuesday, we have fitted an Alugas 11kg and we have aquired a Spanish Repsol.
Our qestion is if I connect a Repsol bottle regulator to my hi pressure fitting on the m/home via a pipe will it work? or do I need something else.
John
scotjimland
2,335
10,108
A Woosh bang
John
If I understand you correctly you want to use a bottle regulator with the existing bulkhead regulator ? .. If so, .....no, one regulator feeding another won't work ..
In order to work you need a bottle adaptor (not a regulator) and high pressure pig tail ..
Jumbo bottle adapter from Link Removed part no •01-1671
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
or this Link Removed
same really.
i normally buy the same in spain at leroy merlin . last one was 11euro.
i tend to find i change almost every thing to the french moroccan ,old uk butane threaded reg . then i dont have to have loads of regulators .
i change camping gas to it as well .Link Removed
tonka
10,833
21,532
Cannock, Staffs
A class Burstner 800
Since 2000
As above, if you try and use a spanish bottle regulator and then feed into the vans regulator it will not work...(Does it Bill / Ambilkate.lol)..
Either get an adaptor which has a screw fitting instead of a regulator..
Or if you have an outdoor BBQ point, you can use a bottle and regulator. Turn off the existing bottle and connect in via the BBQ point. This is how we have do it, like many others...
