Spanish Gas Bottle Regulator (1 Viewer)
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
Can you get a Rapsol gas bottle regulator with a pig tail fitting so i can connect straight to the Motor home regulator?
scotjimland
2,335
10,105
A Woosh bang
yes.. you want a Jumbo adapter.. google it..
http://www.waudbys.co.uk/products/details/17073.html?adid=10735&aditem=17073&dyadid=11031
also from Gaslow
Link Removed
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
have a look here .use the 35mm jumbo adaptor and they can supply a pigtail to suit .
this is an adaptor not a regulator.Link Removed
tonka
10,833
21,532
Cannock, Staffs
A class Burstner 800
Since 2000
As above you DO NOT want a regulator just the Jumbo adaptor..
The thread is the same as a UK Butane clip on adaptor so you can use the same hose /pigtial..
I DO.. ::bigsmile:
laurieash
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
I DO.. ::bigsmile:
Is that a propane as my spanish bottle is propane not Butane
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
propane or butane same connection on spanish bottles .
Emmit
8,034
17,753
Cornwall
Pilote Explorateur
Jan.2014
Greetings,
Just for clarity, the pigtail that fits the Spanish Jumbo Adaptor (for Spanish, say adaptador) you require the same pigtail that fits a UK 4.5kgs Butane bottle .
micky drip
191
121
mid wales
c class
5 years
We are heading for France next week for a 6 week tour.Can I get a pigtail for French cylinder to connect directly to truma regulator ? Can I get one in France?
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
depends on what french bottle you get some use the same butane as the old uk butane.germany ,morocco all use similar.
some french use a 20mmclip on . dont get one of them .
hjeres another good supplier Broken Link Removed
ring them they supply all and just about every fitting
Jun 17, 2012
2,933
9,928
North Essex
Autotrail Delaware
>12 but <13
The french gas from Intermarche has a 21.8l LH thread the same as used by the 4.5kg Calor butane. :thumb: [HI]Take the pigtail with you [/HI]which has the standard connection at the fixed regulator.
Last year I paid €19.90 for the 10kg butane bottle and €1 deposit, so I bought another !!
There are Intermarche everywhere so no worries about running out. Head over running on the Calor bottle then swap.
I spent weeks trying to research and agonised over the right decision. Luckily I had it right and breathed a sigh of relief, the wife doesn't like a cold shower and a warm fridge!
I am currently still burning French gas, will switch soon before I run out so I can arrive in France with some to get me started.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
Broken Link Removed
this is useful it makes that french old uk butane into a propane thread. ideal if you fill your own bottles .
but also means you can change 35mmjumbo adaptor or french /german etrc to uk propane reg or pigtail.
laurieash
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
Hi when in Portugal i had a Butane regulator but got hold of a full Propane Rapsol bottle from one of the delivery drivers, when i tryed the Butane regulator on it it would not release the gas? so scrounged a Propane reg they look the same apart from it says Butane on it.
That worked fine so looked inside and the pin seemed shorter on the Butane one.
Laurie.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
but its the same 35mm clip on . the part i recommended wasnt a reg . only an adaptor . you can then use the bulkhead reg.
even the old uk regs will handle either gas . i know i do it .
i dont have a bulkhead i adapt usually to the old uk butane thread. saves changing reg if swapping bottles.
laurieash
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
Right i think i have got you :Doh:
I need a adaptor and then a pigtail to just swop over when using the Rapsol bottle.
as i dont want to be buying the wrong things:thumb:
Laurie.
