Jim
Ringleader
Jim Brown submitted a new item
Link Removed
Link Removed
Link Removed
Link Removed
Link Removed
Link Removed
We had one fitted a couple of months ago by Vanbitz as well. Nice piece of (expensive!) kit but best to point out that DAB is not standard on it, you have to buy another £100 or so box of tricks to add on before you get this facility.
The DAB is included in the Navigation/Multimedia/CAM44 twin lens camera.We had one fitted a couple of months ago by Vanbitz as well. Nice piece of (expensive!) kit but best to point out that DAB is not standard on it, you have to buy another £100 or so box of tricks to add on before you get this facility.
Yes you could watch Sky sports on it via Now TV or Sky Go with the correct subscriptionDoes it the Sky Sports Channels on it?
JJ
Fitted a Blaupunkt 945 in our Laika and it's been brilliant. Found the code to ROOT it so I could add Google Play Store which is missing. Have now added CoPilot Truck which I have also added to my IPad and Samsung Tab 3. You will be surprised what you can do with it. The Laika has a rear camera and it's own 7" monitor on the dash. The Blaupunkt now displays the route on the monitor when not used for the rear camera. I have SWC on mine and have had all sorts of agro getting it to work. I now have it sorted. One problem you may have if you haven't got the steering wheel controls is how to turn up the volume for the sat nav. There is no volume button for the media channel. I found an apk in the Google Play Store that you can use if you break your volume control. So I can now set the volume of the directions. POI files are also easy to add as are speed cameras. Have fun .. Great Choice .. Ps there are some updates on the Blaupunkt website. Might be worth checking you have the latest.
Is that DAB? with a CAM44 twin lens camera, fitted?Fitted a Blaupunkt 945 in our Laika and it's been brilliant. Found the code to ROOT it so I could add Google Play Store which is missing. Have now added CoPilot Truck which I have also added to my IPad and Samsung Tab 3. You will be surprised what you can do with it. The Laika has a rear camera and it's own 7" monitor on the dash. The Blaupunkt now displays the route on the monitor when not used for the rear camera. I have SWC on mine and have had all sorts of agro getting it to work. I now have it sorted. One problem you may have if you haven't got the steering wheel controls is how to turn up the volume for the sat nav. There is no volume button for the media channel. I found an apk in the Google Play Store that you can use if you break your volume control. So I can now set the volume of the directions. POI files are also easy to add as are speed cameras. Have fun .. Great Choice .. Ps there are some updates on the Blaupunkt website. Might be worth checking you have the latest.
Blaupunkt Capetown 945 is the same as the Dometic .. I paid £490 for mine ( 2016 ) from a Company in Germany .. You can get them on Amazon for £795
Simply select XL Motorhome from the vehicle selection, and use input the weight, height, width and length and it won't take you down county lanesNot a lot of good for junction views then .. The IGO Software shows pictures of junction and lane views .. It does not tell you exactly which lane you should be in. I have played with IGO for a few years. It was installed in an Alpine 920 Sat Nav I had before this one. The other problem I have with IGO is you cannot tell DORIS not to use the local roads or not to use the Peage unless it is necessary. DORIS loves taking you down narrow country lanes to save a couple of yards on a journey distance.
I have just been planning a route through France from Calais to the Spanish Border near San Sebastian. I tried CoPilot which has worked out a route using a couple of stretches of Peage ( Use Toll Roads if Unavoidable ) without to much fuss. IGO on the other hand with the don't use Peage flag set says that a route is not available.
Its identical .. Even the software is the same .. All they do with the twin rear view is use the video inputs .. and YES I have a DAB Radio ..
Hi Eddie.I don't think, but I stand willing to be corrected, the the Cape Town has the same software?
The home screen on the Columbia has a motorhome icon, which lists all of the Promobil camp sites, and the motorhome software allows you to select small medium large or extra large motorhome from the vehicle list and as I mentioned earlier, allows you to input lots of physical data about your motorhome.
The Promobil is on the Navigation home screen not the main appHmmmm .. Looks like you can get a FREE APP for the Promobile camp sites, Once you have it installed on the unit you just put the APP on the front screen.. The Columbia is just Dometic and Blaupunkt getting together. The 945 in whatever guise is a great unit. It is even better with CoPilot Truck installed. The IGO Software has it's limitations one of which is the cost of new maps at £100 a throw. Nicest feature of the Blaupunkt is that you can use any Android based software on it. That is if you can get it to run in the first place. Google Play is missing but can be added easily enough. The base software is the same it's just the little tiny SD card thats got a couple of extras.
As usual anything with Dometic on it is going to be far more expensive ..
That's great if you can.All they have done is use TRUCK software. Hardly niche market when you see how many trucks use it. Days work for a decent programmer at IGO to add a couple of preset buttons to one of their screen layout theme files ..
POI file then for Promobil .. Hardly rocket science .. You can add your own if you know your way round the software file system and how to import KML files and Speed Camera txt files rather than keep paying out for IGO products.
TRUCK software lets you put in exact size of vehicle rather than predefined.
As I said earlier ,, Great piece of kit .. but not at Dometic Prices
The CoPilot TRUCK software iwhich I have added is in my opinion far better and lets you input POI files in TomTom Ov2 format with a small bitmap picture file also. It also has FREE map updates and fixed speed camera database.
Hi Eddie.
I can't find that motorhome icon on mine? Would it be possible perhaps to take a photo of the relevant screen to show where it is? It's perfectly possible I could have missed it as there are so many features there for an old man like me to take in!
Ta,
Bob
