Solar Panels (1 Viewer)
Hakimo
Kincardineshire
Low profile coachbuilt
Since 2011 - after 30 yrs caravanning
Hi - I've been reading about these flexible solar panels mounted on the roof. Does anyone have any experience of them ? - good or bad.
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
there has been many a debate on this forum
There has been many a debate on the forum over the past few years.. it may be worth looking back and seeing what various people have had to say.
I have no axe to grind as I do not use them... I have a 4wk generator built in my chassis linked to a Sterling pure-wave combo charger linked to my two 100 amps (200 total) batteries. Otherwise I use EHU on sites.
Bob:RollEyes:
tonka
10,833
21,532
Cannock, Staffs
A class Burstner 800
Since 2000
No.. But I cant see any reason to pay more for a flexible one unless you just dont have the roof space and need to use the curved overhead area.. The flexible ones are more suited to boats etc where people can still walk about..
Out of interest, just looked up my regular supplier for a friend and prices seem to be down again.. 80w for £108 inc delivery..
Link Removed
mikkidee
212
224
Malton,North Yorks
Since June 08
Hi Hakimo and welcome to the Fun, I don't know about flexible panels, we had 2 80watt solar panels fitted last year. They are the best thing we have had fitted so far. They even charge on a dull day. Hopefully someone will be along soon to answer you question.
Mike:Smile:
slobadoberbob
6,151
1,960
25 years & counting
well thats not going to run my toaster is it
Link Removed
80 watts will not run my toaster will it:Sad::Sad::Sad::Sad::Sad:
Bob
ShiftZZ
21,383
84,579
Dark Side of the Moon
Bob:RollEyes:
So the answer is no?
slobadoberbob
6,151
1,960
25 years & counting
I did look at them recently
Yes it is NO but I did look at them when I was thinking about a wind power un it.. I also looked at these flexible solar panels... but as said designed for boats and can be walked on... as my roof has a lot of kit on it from the winguard arial, fridge vent, air con box, satellite dome, roof light, and a bubble over the shower area plus other vents, I have a fairly small area.. and 80 watts is just not big enough to make any differance to the amount of power I use. The shadow issue is still a problem, especially for me.
But I like to see my 200 words work still rather than just NO:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Bob:Blush:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hi bob .you could get a decent van one with a gas grill. dont use any leccy then.
simplicity works every time.
as to the flexible solars . the real question is why .
most arent even worth the effort of un rolling . unless space is verty limited as said £io8 including delivery and the same compny can do very good regulators to match.
i imagine op. was talking about therapy 2000 in stoke prior. excellent service from them.
14,741
76,023
UK
Self Build
I am toying with the idea of getting some of these for the side of the van. I had a small one once but never got round to fitting it.
They are really thin and would fit within the side panels of the van. This would just be to give me an extra early morning late afternoon to complement the ones on the roof.
Just a thought at the moment, I have loads of other stuff to spend money on before I get to that...
slobadoberbob
6,151
1,960
25 years & counting
we use a cobb for cooking mostly
We mainly use the cobb unit for cooking and we have a colman unleaded fuel double stove in reserve.. as the RV is LPG cooker and also fridge.. we only use the batteries to power the TV via the inverter (230v).
Bob
GJH
29,450
38,827
None, now sold
2006 to 2022
Interesting to see Bob's comment "80 watts is just not big enough to make any difference to the amount of power I use" because that sums up the crux of the matter.
Using power hungry devices (even conventional bulbs) carries with it a requirement to have a means of generating significant power.
I've changed all our internal lights to LED and apart from that we have the water pump and blown air heating pump (which take relatively little power) plus charging of laptops, phones &c and, every now and again a low wattage 12v TV for a short while.
We have a single 80Ah battery but because we use such a small amount of power it is more than adequate. The 80W panel we had fitted to the roof more than copes with replacing the power we use each day. It was putting in a small charge even in the rain at Chester this morning.
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
when off hook up, our solar panel charges battery enough for lights an a couple of hours tele, no problem.Never flattened battery yet and are not over carefull even in the uk.
haganap
12,760
26,450
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Just a thought Gromett, Would it be legal to add them to the side of your van? With the reflection whilst driving could you not dazzle others and possibly cause an accident?
Not sure as I have not seen the flexible ones,
14,741
76,023
UK
Self Build
It's on the side of the van...
It's in the same place windows would be.
It's slightly angled up.
They are not as reflective as rigid panels as they don't have a glass front to them.
Hmm? I think that covers it:thumb:
sabconsulting
16
4
High Wycombe
Demountable truck camper
Since 2010
I have the regular panels, so I can't offer any advice about the flexible ones based upon experience.
However, one thing to consider is that there is no air gap between the flexible panels and your roof as there often is with regular panels, so in a hot climate they could absorb a lot of heat and transmit it to the roof of your motorhome (a bit like painting your motorhome roof black). Also, as the panels get hot their efficiency reduces.
Not a major concern, but something to throw into the mix when considering buying them.
Steve.
14,741
76,023
UK
Self Build
You are correct the heat could be transferred to the van roof. However if I was to install one I would use a thin layer of Sikaflex which would insulate it.
If it did conduct to the roof this would keep the solar panel cooler and more efficient though :thumb:
oldun
747
162
St Neots
VW Campervan
Since 2001
Bob
With an 80W=watts solar panel will be lucky to get 50 watts even on a good day in the UK (50+ degrees north).
50 watts at 240 volts is about 0.25 amps not much use for mains power, ideal for keeping a battery topped up for lighting and powering the pump and 12V side of a gas heater.
