solar panels (1 Viewer)
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
about how long will an 85 amp leisure battery last if it is runnung an LCD tv and lighting and how big a solar panel will i need to recharge the leisure battery
Depends on how much current these items are drawing, Brian and John will no doubt come along with their advice.
Peter
43,334
49,531
Hi Paul,
at a rough guess id say around 10 to 12 hrs, with nothing else running, before the battery needs charging but a lot of variables are to be taken into account. ie: quality of battery, state of charge and power usage of tv etc.
you should never run down a battery below 50% (and preferably not less than 60%) of its full charge....40% to 50% used.
if your tv is 2.5amps/hour then you need to put 2.5amps/hour (minimum)back into the battery.
2.5amps should equate to a panel around 50w to 60w, on a bright, sunny day.
but you'll be using other things as well...lights, water pump, possibly blown air heating fan etc.
personally i'd say a 100/120 watt panel would be ok.
a cheaper starting point would be to replace the 85a battery with a couple of 110ah ones...that will give you 2.5 times longer battery life before you NEED to recharge.
wireman
147
Chesterfield
an even cheaper one is to add another 85 amp hour battery and get double the time you have now. We have done this last year and the batteries lasted 5 days without hookup and not running the engine without much problem It needs to be pointed out at this juncture the fridge was on gas and we only used the television for about 2 hours in total and lights maybe 2 hours a day and we are pretty frugal with them even then. Hence the solar panel (80watt) sitting in the hallway ready to be fitted when the weather improves...(France in the summer is a good place to be)
2,345
10,186
There are quite few good Solar Power Calculators On-Line
This one looks quite good and has a lot of other useful info .. with a FAQs page where you can also submit a question.
http://midsummerenergy.co.uk/solar-panel-information/Guides/CaravansAndMotorhomes
We manage 3 days on that battery with heating/TV/lighting. Just did that over New Year and the battery still had more left in it. Truma was on continuously. TV only about an hour a night. We do have all LED lighting.
People keep saying MORE BATTERIES, beats me. Yes we would manage 7 days on two but then it takes twice as long to charge. The vital thing is, like your finances, if what is coming in does not match or exceed what is going out you are stuffed sooner or later. A million batteries will only delay the inevitable.
Solar is so very variable that only experience will show what you need. 100W is a big panel for a starter. Add another if you need to.
2,345
10,186
I agree with you Brian, for years we managed on one 85ah battery with no solar or genny and in the early days we never even had a leisure battery, the engine battery was adequate .. and in our tugging days we never had any 12v in the van .. gas was king, fridge, lighting and heating were all gas, water pump was a foot pedal by the sink.
However, things have moved on apace, people want and expect to run all manner of electronic goodies, vans have become power hungry, accessory shops are stuffed full of goodies that need more power..
Solar is an excellent way to provide more but my first step would be to add another battery , a cheap way of effectively doubling your time off ehu .. adding a solar panel without beefing up the storage first is like turning on a water tap full to get a better wash without increasing the basin size fist .. no point in producing power without somewhere to store it.
Hit nail on head !
KISS
Jan 11, 2010
2,749
9,583
Chester
Auto-trail
solar
Solar is an excellent way to provide more but my first step would be to add another battery , a cheap way of effectively doubling your time off ehu .. adding a solar panel without beefing up the storage first is like turning on a water tap full to get a better wash without increasing the basin size fist .. no point in producing power without somewhere to store it.[/QUOTE]
An excellent quote and I agree 100%, never thought of it that way before, though like most of us we new the answer just didn`t put it into the thought process.
A friend of ours has his boat next to ours in Greece, he fitted 2 x 80 watt solar panels from 11am until about 4pm he has to cover them up as they produce far too much power than he needs, his batteries are full.
I know the genny is noisy and you have to carry petrol, (unless you convert to gas) but you only use it when you want the power.
2,345
10,186
If you are an all season camper and don't want to be tethered to an EHU a genny is a must, unless you are moving on every other day.
I hate to see arguments about solar versus generators, in fact, I would argue that if you want to stay off ehu then they go hand in glove. When the sun don't shine the genny is king.
As a newbie to motorhoming, power can be all very confusing, there is a lot of conflicting advice, Brian says KISS .. and I agree, but modern motorhomes are anything but simple .. in the 'olden' days we thought it was the hight of sophistication to have a 12v lead with one light hung on the end fed from the car battery .. ohhhhhh happy days :roflmto:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Happy days indeed
The whole ethos was at one time to get away from the Tv,radio,and phone they called it feedom:RollEyes:
Now your roughing it if you havent got Tinternet, films on demand and on line banking in yer tent:Doh:
My how priorities change:RollEyes:
Geo
2,345
10,186
Happy days indeed
Geo
Exactly Geo ... when we were away for a year or more people couldn't fathom why I wasn't on forums.. never answered email , but I had no inclination, there was so much other things to do and enjoy, stuff you can't do from an armchair.
My idea is to GET AWAY .. to cast off and see more than just a 15" LCD screen and to at least try to magine you are a pioneer on an adventure .. even if only for a while. Others are different and want a home-form-home ..
There is no right or wrong.. but my roots are in tenting, and even today I still yearn to get away and do it again.. If I can only drag myself away from tinternet :ROFLMAO::ROFLMAO:
imprint
1,087
13
One small point, wireman suggests adding another 85 ah battery to the existing one.
I believe it is considered bad practice simply to add a second battery and retain the existing one ; batteries should be fitted or replaced as a pair.
That said, follow PJ's advice, and fit two 110s rather than two 85s. The difference in cost should not be a lot, and anyway, in general, you never want to get much beow half capacity, if that. And don't try to compromise by fitting one 110ah now, and another when you realise the original 85 is dead!
23,836
72,539
In all my life and all the forums I am on I have never once felt the need to blank someone.. Jeez I am finding it hard not to at the moment...
What a prize &&&&!!!!***
Douglas
2,835
400
South Wales,
People come to these forums and sometimes ask for technical help, they ask for help and information because the need to as they do not know them selves.
Now is some one answers that call for help and information with incorrect answers, the the poor guy goes away and acts on the wrong information.
Most of the time it wont make a lot of difference but every now and again the incorrect information get the enquirer into a lot of bother.
Surely we have an obligation to give correct information or say nothing!
So I ask again tell me what make and model of LCD TV consumes no more that 2.5 amp?
Doug...
SandJ
1,799
818
North Yorks
Too long lol
Doug...
I agree
Doug...
I will not mention grammar as I never do that
So .....again I agree
Doug...
Again I agree, with some of it
Doug...
As I am in the position to be able to answer this one.....I will
A broken one :Eeek: :thumb::thumb:
I think the point is, yes accuracy is needed in some situations, but not all the time.
So what was the question?
:ROFLMAO::ROFLMAO:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Doug you are making a fool of your self big style
John said IF your tv was 2.5 amp, the same would work if he said IF your tv was 600amp
It is only you being caustic with your reply that make no sense
If you know the answer post it
If you dont,
Take your own advise and say nothing
Geo
chatter
3,689
937
cheshire
5th wheel
Please tell me the make and model of this LCD TV.
Doug...
maybe i can answer this question Doug
the Akura -AHLTV15 - is a 2.5a
features of the tv are
1- Multi band TV reception.
2- Full function Infra-red remote control.
3- Scart Input.
4- Analog RGB input (PC VGA)
5- CVBS and S-VIDEO input.
6- PC and CVBS Audio inputs.
7- Coaxial Audio output.
8- 2 x 3W internal speakers.
and i have one for use in my van, very lightweight and for the price an excellent bit of kit and picture plus it comes with the 240 lead and a dedicated 12v lead for the van.
you can also get one with builtin freeview for around £150, that one is a 4.5a
43,334
49,531
as i said once before doug...if you have a problem with any of my posts then send me a pm.....don't try to belittle me on open forum.
IT WONT WORK!
i still cant see what iv done to get you upset.
you dont HAVE to read my posts.
still waiting for the PM.....
but that doesn't get the same satisfaction of attempted belittlement or the response to be got from an open post so i dont expect one. :Angry:
i cant put you on my ignore list, as much as I'd like to, as it dis-joints some threads but all future attempts at belittlement will be ignored....i have better things to do and plenty of useful advise to give.
subject closed.
JJ
Mágica
May 1, 2008
19,259
48,056
Burstner Privilege T
over 50 years
subject closed.
The quality of mercy is not strain'd,
It droppeth as the gentle rain from heaven
Upon the place beneath. It is twice blest:
It blesseth him that gives and him that takes.
JJ :winky:
