solar panel (1 Viewer)
can any tell me how to connect my solar panel to my pioneer renoir thanks kevin
  • info
    Votes: 0 0.0%
  • info
    Votes: 1 100.0%
  • Total voters
10,117
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
dont recognise the motorhome do you know if it has a specif make of electrical distribution systen?pictures might help
failing that you can go direct to the leisure battery via a controller
Aug 10, 2012
839
891
cambridge
Globecar
since2001
Kev
connect the panel to a solar controller, then the controller to the battery, simples
The controller will have a simple diagram,
You need a controller, don't connect the panel directley
Type of motorhome doesn't matter
simples(y)
ps welcome
:welcome3:
Welsh girl
3,658
3,036
Globecar
Since 2004
We have a Sargent unit that states on it that it has a 'built in dual channel solar regulator for direct solar panel connection'. I was wondering how that can be connected to a solar panel so I will be following this
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
There is another thread running right now detailing this.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
I must ask why anyone would take the trouble to get good quality solar cable then feed it into a built in regulator to pass on via damp string and printed circuits to your battery.
Cut out the crap and go direct to battery via a "proper" regulator man enough for the job
Jaws
23,836
72,493
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Absolutely spot on Geo ! (y)
Cal54
3,806
62,035
Southport, UK
Leisuredrive Renoir
Since 1996
Pioneer is an altentative badge for Autocruise from back in the day when they were independent and manufactured coach built MH's.
Aug 10, 2012
839
891
cambridge
Globecar
since2001
Simples but TOTALLY WRONG. Learn from JJ or destroy the battery.
post removed
Cant believe I'm wasting time on this thread
Just read Jims post about his daughter, puts things into perspective some what
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Thanks for the abrupt reply:p
Had the OP taken your advice the battery would probably have been destroy. Someone had to save the OP.
The "Learn from JJ" was intended for the OP though I did not make that clear enough.
Aug 10, 2012
839
891
cambridge
Globecar
since2001
post removed
1,662
4,673
Sheffield
Eldis Majestic 115
Vans and tugs since mid 70's
I was advised by Sargent when exploring fitting a panel that to no way connect direct to the main EC400 unit with anything greater than 80w. We have now 2x100w plus a standby 40w for the early and late months. Solely EL fridges demand it. Like most have advised regulator to batteries first.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Regardless. No current flows until the circuit is complete. So whether it connects the controller to the Panel or the controller to the Battery, there is no current flow until the last connection is made.
However, best advice would be to make the supply (panel) the last connection, and preferably the negative feed.
Geo`s advice to ignore the Sargent, and go direct with a decent solar controller with the capacity to manage the panel output would be the better approach, Voltage drop in cable is anathema when using low voltages!. (a load of 1A drops 0.0083V per M run @12v Nom) on 4mmsq cable.
Pete
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Getting better month by month.
Pete
The reason the batteries should be connected first is so that a regulator that can charge both 12 and 24 V set ups, knows which voltage set up you have.
