Solar panel installed on roof rails (4 Viewers)
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
I will install my 100w panel in the coming days and whilst planning the location on the roof I thought that It may be possible to use the existing factory fitted roof rails to mount the panel on to.
The location would be in the top right hand of the picture i.e. up against the side rail and in between the 2 sun roofs.
My idea is to use some mate bolts that would slide into the rails (see Alu profile below) and then drill relevant holes on the Alu C profile of the panel, these would be secured with relevant nuts and washers and then some thread lock.
17,630
43,338
I have seen them used before using ali angle between the cross rails and then the panel fixed to them. make sure you use stainless steel fittings though to prevent rust which will corrode the cross rails very quickly
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Here is one where I used two sizes of stainless steel U bolts. Just to offer ideas
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Fitted mine on the Adria and a friends on a Rapido to the roof rails, no problems.
Used alloy box section and stainless screws with nyloc nuts.
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
I like the U bolt idea, will search some out tomorrow.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Forget threadlock just use nylock nuts
I doubt either method will work as your rails are too close to the roof for you to get your hand under the panel and fit/tighten the nuts.
Personally I would remove two rails and have free reign
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Cheers Andy, shame we couldn't have met up for the install at Easter, gives me something to do at the weekend though:winky:
Nov 14, 2009
425
252
normandy
c class
16 years
i have done the same , only i have hinges down one edge of the panel so i can prop it up and take full advantage of the low winter sun making the panels useful all year.
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
ok mounted with some U bolts but as Andy had pointed out with the rails beinf so close to the roof i had to make some 25mm spacers so i could get my hand in to tighten the nuts. All is extremely secure and most of the cable is run as well. Like this I can easily add another panel to the left at a later date and still leave space for aircon or a roofbox at the back, plus it's located just behind the luton's bump so hopefully it won't add too much drag
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
job done.
would have been easier with rachet ring 13mm spanner due to that tight access inbetween the panel and the roof but hey then it wouldnt have been as much fun...
Sunny days ahead:winky:
Techno
Jul 28, 2010
15,475
20,756
May 2010
Would have been easier with rachet ring 13mm spanner due to that tight access inbetween the panel and the roof but hey then it wouldnt have been as much fun...
Sorry I could have told you that :roflmto:
I also made sure the U bolt threads were not overly long
EDIT Nice job matey :thumb:
Sep 3, 2012
7,555
26,076
Cheshire
C Class Elddis 175
8+ years
Hi Andy
I am about to take the plunge and purchase a couple of 100w panels -I intend to fit them to the roof bars which are already on my Sundance, similar to the pictures you show, but down each side of the roof vent
can you please advise how the u bolts fasten to the panels -i cant see any of the threaded U bolt ends or any holes in the panels where they bolt to.
if you have any photos that would be great.How many u bolts were used per panel -any attached midway for example?
:helpsos:
cheers
jim
geo glasgow
292
274
Glasgow
Auto-trail cheyenne
i like this idea
make it so it can be tilted to the sun, very cool..
:thumb:
Techno
Jul 28, 2010
15,475
20,756
May 2010
Four U bolts
Drill the frame
Shorten the threads so just long enough to take a full nyloc nut
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
job done.
Nice job, you could get another 3 up there!
Allan
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Four U bolts
Drill the frame
Same as Andy did. I positioned the panel on the bars and then marked out the locations for the holes. The Alu profile on the panels is a C profile so there is an approx 30mm lip underneath that you don't see on the pictures. Just drill the 8 holes with a slightly oversize bit as it will be easier to locate them afterwards.
My bars are very close to the roof so I fitted some spaces to lift up the panel away from the roof and allow me to get my hand under to tighten the 8 nylon nuts, having said that I realised afterwards that a ratchet ring spanner would have saved me a lot of bother:thumb:
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Allan
Been using the 1 for the last few months and it's been great to be able to avoid hook ups on sites. Not done any long stints yet so maybe another 100w panel could go up there soon:winky:
Nov 24, 2008
867
2,168
Anywhere that takes our fancy
Since july 2009 And Still Going Strong
Self install/insurance
I wanted to put solar on my roof myself but thought I'd better check with my insurance company, they said NO as they had to bit fitted professionally with certificate/receipts supplied. Am I with the wrong insurer or should I just not tell them? Annoying when I'm more than capable of fitting them myself. Cheers Shawn
stcyr
1,765
1,160
Normandie
Our roof rails slide along the siderails so they can be repositioned anywhere along the roof. They are 'I' section and are exactly the right size to fit the solar panels into. One rail tightened, slot panel in, move 2nd rail along, slot other side of panel in and tighten the bolts that secure crossrails to sidebars - job done. Takes about 4 minutes to fit or remove a panel.
:thumb:
Allanm
5,431
9,192
Since 1987
We have a puny 30w panel and 2 x 105ah batteries. Even in December we were able to spend 2 weeks travelling around with no EHU. Thinking about upgrading the panel soon. The controller will cope with 120w so I might go for one of those
Allan
Sep 3, 2012
7,555
26,076
Cheshire
C Class Elddis 175
8+ years
Four U bolts
Drill the frame
Thanks for the answers -silly me didn't realise the panels had a C frame. I had cut out some hardboard templates to see what they looked like in position and if i could fit 2 panels :thumb:
Fireman Sam
1,421
2,513
Bushey
Class C
Only since 2012, but I towed for many years
What an inspiring thread. Many thanks to all contributors.
