Solar Fuses - Do I Or Don't I Use Them? (2 Viewers)
Sep 9, 2014
168
102
Coach built
Summer 2014
Just about got everything I need for my instal apart from some dry weather and fuses!
Depending on where I go for information I'm left a little uncertain about fusing needs. Should I fuse between the panels and controller, some say yes and some say no.
If I do need to fuse should the fuse be at the panel or controller end?
More importantly what fuse size and should I fuse both positive and negative inputs?
I've got two 150w panels which will be connected in parallel.
Panel specs:
Max V 17.8V
Max A 8.43A
Open circuit V 22.3V
Short circuit A 9.1A
Controller is the one used by Andy, Techno 100. 25A/300W MPPT by Maximum Solar
Understand the need to fuse between the controller and fuse close to the battery terminals. I've got 2 x 100ah (traction type I believe) batteries for leisure use. I also have a pair of midi fuse holders to fit, but what size fuse do I fit there?
All advice gratefully recieved:)
Jun 10, 2010
8,518
20,232
Shrewsbury (sometimes)
N&B Clou Liner MAN
The supplied instructions say no
Andy I note on your photos that you have the same mppt regulater as lots of us.
Sorry if you ve been asked this a thousand times before; but what do the wires from your 'load' terminals go to?
Ive tried searching but you have a lot of posts.
Jon
J
Sep 9, 2014
168
102
Coach built
Summer 2014
Without digging around just now, I'm certain that I've seen photo's of your instalation with fuses Andy...I could easily (and probably) be wrong though!
Fuse size at my batteries anyone?
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Yes I use a fuse but its not necessary
Fuse to batteries needs to be bigger than your max output 25amp is fine
Feb 27, 2011
14,741
76,030
UK
Self Build
I personally fuse anything capable of generating a spark. My solar panels have a fuse on the roof for that just in case situation. I fused both ends of the cable running from my battery to my solar controller. Only fused the positives.
