So what is the Answer? (1 Viewer)
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Extended travelling in France Spain or Portugal, how do you guys manage for Gas?
Is it Gaslow or adapters or what?
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Cheapest and simplest way is buy a local bottle and regulator. LPG to fill a UK gas bottle is not on every street corner in Spain.
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
We have two 11kg Gaslows. Also we have discovered that a French bottle will fit straight on if we needed to. :thumb:
Jim
Ringleader
Jul 19, 2007
36,421
130,932
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Gaslow for us, but I'd prefer a decent sized under slung tank. That way I could turn my exsisting gas locker into a welly locker and have it house an extra leisure battery as well:thumb:
Popeye
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
Thanks for that, the underfloor tank makes a load of sense, I've got oodles of space under the floor, then I suppose I'd have to get a filler neck plumbed out to the side of the van.
Mind you, Ken's solution has to be cheaper and less fuss.......what sort of cost are these Gaslow systems?
scotjimland
2,335
10,105
A Woosh bang
Agree with Dave
I had an large LPG tank on the RV, relatively easy to fill up in France but not Spain... so after entering Spain I kept the tank in reserve and used a local bottle.. same when we went to Morocco ..
It's also less hassle to buy a bottle on site than to de camp and take the motorhome looking for the stuff ..
Flexibility is the key word.. have Gaslow/fixed tank by all means but keep your options open and be equipped and prepared to use local gas when needs must. By that I mean have a method or facility for plumbing in a bottle .. ie a BBQ point or other facility.
Jim
Ringleader
Jul 19, 2007
36,421
130,932
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Every time we go to Spain we see more LPG, MUCH more. in Portugal it seems to be more abundant than the UK, seemed every other garage had it on the Algarve this year.
Heyupluv
3,862
1,593
France,
touring many years..42+
We have Alugas refillable...2 x 11kg.. external connection fill...the same as gaslow but half the weight when full...That is for.. France, UK, Spain, Portugal, Belgium, and Germany
pablomc
772
237
Durham
Since 2009
.....what sort of cost are thes Gaslow systems?
Have a look at GAS-It. Same as Gaslow. 2 x 11KG bottles and everything you need fittings and adaptor wise for £317 (delivered free).
chatter
3,689
937
cheshire
5th wheel
Having a 5ver we use the gaslow adaptors then just buy local bottles when needed and use the relevent adaptor, we have 1 for the spanish bottle and 1 for the french 'le cube' bottle, you can get adaptors for all of the european countries.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
i went with a single gaslow 11kg but i wish i had invested the money in an underslung tank as they are bigger and less hassle and not much more expensive.
although there are advantages to both ways its all down to weight.
if you are running with 2 x 6 kg calor bottles it will cost around £20 to refill each one where as an 11kg gaslow will cost around £13 to fill and will sit in your existing locker.
if you decide to go underslung then you have another big space made available so inevitably the old gas locker ends up becoming the generator storage etc. and you end up carrying more weight mainly because you have the space so you are going to use it.
personally i would go with a 80 litre underslung tank fitted with stainless steel straps as the normal steel ones rust away and the last thing you want whilst doing 60mph on a motorway is effectively a bomb falling out from under your van.
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
If you have a Gaslow system you can connect a foreign bottle to it using the Gaslow Reserve Cylinder Connection Hose. Details on the following link.
Link Removed
Got mine from Dave Newell.
Brisey.
jb0371old
465
408
Norfolk
Autotrail
1 year
Looking at the cost of a gas system myself. Prices I have been quoyed for just 1 11kg refillable system are as follows
Gaslow - £270
Gas it - £165 - free next day delivery
autogas - £175 (steel bottle)
Looked at the aluminium bottles but cant really justify the extra £50 a bottle to save 4kg.
Or just go for the underslung option
GJH
29,450
38,827
None, now sold
2006 to 2022
As with so many items, what price does one put on convenience and peace of mind?
When we got our van back in February we had a single 11 Kg Alugas bottle installed and continued to carry a 6 Kg Calor as spare. After a while we decided we would like a second Alugas bottle, probably towards the end of the year but circumstances then dictated getting a second one earlier than we had planned. Yes, it cost a bit but the freedom it gives us was - for us - well worth it.
Same can be said of the solar panel we have.
To go back to the OP though, I still reckon the best solution is to not cross the Channel in the first place :ROFLMAO:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
#Not really a good idea Jim the locker would have gas pipes and connections all of which could be the source of possible gas leaks, do you really want to put a spark generator in there, I wouldn't.:Eeek::Eeek::Eeek:
43,331
49,460
a good converter would move all the pipework to the underbody leaving the locker free of all gas bits and pieces.
a cowboy converter may just extend whats already there.
Minxy
32,656
66,564
E Yorks
Carthago Compactline
Jim - If that's all you want to use your locker for, it would probably be cheaper to have a Beeny box installed instead. When we were considering getting a fixed tank fitted to our new van (before I managed to 'encourage' the 11kg Gaslow bottle into the locker using a lump hammer! :thumb: ) we were quoted around £770!!!! :Eeek:
sedge
Jul 7, 2009
5,504
13,117
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
It would have needed something more substantial than a liump hammer to get the 11kg Galslow bottles in our gas locker - so do check on dimensions of them and you gas locker door, before ordering 11kg of any brand.
Locker itself plenty big. Just the daft door ......
Hence we use two 6kg Gaslow ...... we very rarely stay on a site so hence no mains this year for a month we went nearly full (had filled up towards the end of a few days in Norfolk earlier in the year) and grabbed two refills when the opportunities arose oce in the middle when we had just started bottle 2, and ditto right at the end of the month on the way back in Dunkerque ISTR - because it's cheaper in France is all and saves having to do a 15 mile trip to fill it up at home, before we go somewhere next time.
We keep having to say this on similar threads about 'measure your door' - think it ought to be a ruddy sticky by now! (been saying for over 3 years at this point LOL)
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
what you need is space for a 19kg uk bottle and a spanish bottle . as soon as you get to spain exchange for a full one ./ far cheaper than lpg auto gas. if going to morocco get a maroc bottle .next year just use spanish and maroc . if in portugal there are places that will fill your uk bottle . if you cant. but even there its ckheaper in the bottle than filling with auto gas . if staying in spain its easy to exchange the spanish its every where . the uk bottle used for emergencies will last all winter i,m sure . never quite seen the point of gas low or the others when abroad . can almost see the point in uk but they are expensive to obtain .
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Link Removed
Brisey.
Great, and of course it will fit Alugas, Gasit or even a fixed tank installation (if the tank is empty) as the filling point is the same on all these systems.:thumb:
