Smellywater (1 Viewer)
Sep 21, 2013
226
241
Isle of Wight
coachbuilt
since Apr 2013
Got a problem with the water coming out the cold water tap on the kitchen sink smelling of bad eggs.
Its in a 2000 Hobby 600 if it makes a difference.
I took the inspection cover up over the cold water tank and removed the inspection cover, No smell came out so I dipped a glass into the tank and that was odourless too.
I then tried water from the bathroom sink, again odourless while the kitchen was still smelling.
Apart from not using the kitchen cold water any suggestions as to the cause and any remedy to it
Jan 28, 2008
10,117
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
if its not in the tank and not in other taps its got to be in the pipework up to the kitchen tap i would suggest dosing a full tank with purifcation tablets and running it all out via the kitchen tap
43,331
49,466
it sounds very much like Hydrogen sulphide but as the other taps are ok it would appear to be the kitchen tap itself.
Chlorine is the usual method of removal in water but i doubt it would work in unaffected water passing through a contaminated tap.
Are you 100% sure its not from the hot tap, assuming you have a mixer tap.
the taps hot and cold feeds could have been reversed from new or after a repair and you think its cold water but is actually hot.
Hydrogen sulphide is more often found in hot water and it could be the boiler is contaminated.
Easiest but most expensive cure would be renewal of the tap and pipework back to the nearest junction.
movan
21,492
120,753
Moving around
Burstner
since07
This might sound daft ... in fact coming from me it is quite a high possibility .:Doh:.... but I am paranoid at the moment about mice having found another load of droppings in the store holder of my van yesterday ... is there any chance there is a dead mouse in the pipework .. (that's where I had one leading up to the bathroom sink ...:Sad:)
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
I presume you are talking about your water pipe...
I think the pipe is too narrow even for a little mouse, and if by chance one did get in it`s decomposing poor little body would certainly stop water coming out of a tap, bless, poor little mouse... :winky:::bigsmile:
Waste pipe may be different, although you have a tank,,,, if the drain tap is left open, a wee little mouse could get in through the waste drain tap, and into the tank and work it`s way up the pipe... poor little thing.. but doubt it, Joy...:thumb:
movan
21,492
120,753
Moving around
Burstner
since07
:thumb:Thanks Mo. They just said water pipe so I thought the sink pipe cos that where the poo was in the cupboard under the sink tap in the bathroom ..... and other places of course.:Sad: I always leave the waste water tap open when in storage....
Sorry Vection, didn't mean to steal thread. :Blush:
spitfire
2,408
5,135
Correze France
Bavaria
Since 2003
We have a similar problem at times with our 750 but after flushing through all the taps and refilling the tank all is fine .
Fermenter
54
19
Lancashire
Burstner
Since 2012
Most definitely H2S and almost certainly bacterial growth on protein products and likely on the pipe work from what you have described. As bacterial then chlorine treatment of the water tanks and flushing thro the pipe work allowing chlorine to act for a few hours before rinsing thro should sort it out.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Same happens on our narrowboat if water dosent pass through the charcoal filter for a few weeks. We just run the tap for a bit, it soon goes away. :thumb:
JockandRita
11,462
150,163
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
We have the same problem in our Hymer, but at the vanity unit tap. The water runs cold, then hot (and smells), then cold if left to flush. It is caused by the cold pipe being strapped next to the hotpipe by the installers.
I have tried to trace the pipes back to the boiler, and separate them as much as possible along the way using polystyrene spacers, but they go up behind the boiler and over the wheel arch. That's the area where I've been unsuccessful.
It does clear altogether with the annual flush and soak with white vinegar, but soon comes back when water has been left standing in the pipe work. It's at it's worst, when the boiler is on.
HTH,
Jock.
scotjimland
2,335
10,108
A Woosh bang
good advice..
Cheap non scented thin bleach , (that's important, you don't want lavender smelling water) .. a couple of cups in a full tank, run taps, both hot and cold, until you can smell the bleach.. don't forget the shower.. leave for 30 mins, drain and flush..
as used in factories, public buildings, office blocks, swimming pools, etc. to sanitize water systems..
