Slightly Fed Up (1 Viewer)
supabrigg
8
8
north notts
hobby 750
5 years
Just thought I would let folk know how my luck is these days, test on bus said slight play on front wheel bearings but only same as last year.So as I am going to Europe soon shall I have them done or risk it.With my recent run of luck I decide to have them done as if they went on holiday i.d feel a right idiot.460 pounds spent and we are off, 6 miles from dover and guess what? RAC out and you ve guessed right yes bearing gone, police arrive and because rac can.t give a time to move me police call there people who still take 1.45 to move me and charge me 150 pounds to go 6 miles.Brought 220 miles home next morning so instead ofTournai today it s Tesco to stock backup. Still its only money and missed holiday and I suppose I could have stayed there and had it fixed but when you are in this situation you can t think clearly and I just wanted the people who did them to make it right so opted for home.Thanks for listening, going to the pub cheers mick
Puddleduck
12,385
43,990
Scottish Borders
Without at present
On and off for many years.
So sorry to hear this. I hope you give the people who are supposed to have done the repair hell. They should refund ALL your costs including your disappointment at the loss of your holiday.
Their mess up could have resulted in a serious accident.
If you get no joy then name and shame.
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
That's sounds tough, but now we need more info, I guess you do too
Did the repairers fit original parts or compatibles
It shouldn't really be the repairers fault unless he has fitted them badly or not fitted new just told you he has
Hope you get it sorted though and soon enough to get going again :)(y)
9
9526
Hope you get it sorted supabrigg, the garage have some explaining to do.
Oct 20, 2014
452
2,537
Wicklow Town, Ireland
2020 Avantgarde 175
A good few years
Sorry to hear of your woes. No way should new bearings fail so quickly???!!!..... I'm with Jollyrodger on this....hope you get satisfaction.
rolandrat
436
258
Lancashire
Hi Top
factored parts are always a gamble as far as front wheel bearings are concerned but how are you to know what the garage has fitted. It once happened to me and apart from the inconvenience they were replaced F.O.C. It is common knowledge that pre X250's could be troublesome and Fiat changed the specification.
S
supabrigg
8
8
north notts
hobby 750
5 years
thanks for all replies, chap who did job has serviced and repaired all my vehicles work and leisure and I ve always trusted him and he has always gone the extra mile to keep my work vans on the road.I will keep you all informed in case it helps someone avoid same happening to someone else.cheers mick
Apr 13, 2012
5,545
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
Sorry to hear your bad luck, something similar almost happened to my 2004 Ducato... heard an occasional squeak from the brakes, took the van in for a service and noticed black streaks on a wheel......... wheel was too hot to touch.
No doubt the bearing would have failed very soon, had to have new calipers and a bearing....... lucky I spotted it
The problem with most MHs is lack of use, that's what I put the problem down to
Carol
14,051
112,114
North Wales.
Oh heck hope you get it sorted, talk about Murphys Law.
Jaws
23,836
72,484
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Sounds like some of my luck has rubbed off on you :(
If the wagon is either a Fiat or Pug, the front wheel bearings are always a tad loose.. In fact the MOT tolerance for them is quite a lot..
If the failed bearing was fitted by a garage I would suggest you tell them about it and say you are taking it to another garage to get a report.
If the report comes back with anything iffy you should be able to get all costs and compensation from the original garage
Jul 12, 2013
3,872
5,275
The City of Henlow
Adria Supreme
Since 1980
Thank you very much for pointing out potential problems. I am only sorry it had to happen. Although I appreciate your thread, I can hardly put 'Like'.
Regarding responsibility for the failed part, there is only so much effort worth putting into sorting it out, without simply adding to your pain, for you trust the garage and are presumably a valued customer. Parts can fail! Fitters can make mistakes! I do feel sad that some problems can be chased to death, nobody really winning, while I also accept that there are occasions when the guilty should stand up and pay. This seems to fall into the first category, you lose but the part is now replaced and nobody really knows where the fault lay.
Alan
