Sink (1 Viewer)
oldseadog
3
Cornwall
elldis
elddis firestorm 150 '58reg.
My bathroom drain has decided to unplug itself with a little help from his friends. All I see is a hole which disappears down behind the toilet cassette has any dear friend an idea as to how this can be replumbed.
:cry:
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
To avoid stripping it all out if you can 'fish' it back up and through the hole (try using a wire coat hanger bent accordingly) the fibreglass around it with some ribbon matting in white gel coat.
Bit of a bodge apart from that get the tray out and reinforce the drain underneath to effect a repair.
Peter
O
oldseadog
3
Cornwall
elldis
oldseadog
Dear Peter
Thanks for the info: the drain is now emptying into the 'bog' as I had to cut a hole in the bottom of the sink to tighten the drain internally. The inside of the sink had filled and the extra weight dumped it on the deck via herindors toes, pulling three feet of pipe with it. I don't think there's enough internal pipe in the 'ole to be oiked out. None the less I shall give it another go.
Best wishes
John
Carol
14,051
112,114
North Wales.
Hello oldseadog Welcome to Motorhome Fun , hope you get your sink out,:welcomefunster:
