Sink drainage slow (2 Viewers)
Mark5204
229
60
Bristol
Swift
Newbie
looking for advice. Filled kitchen sink today first time we have used it ourselves. When it came to draining water from sink it was stupidly slow. Any ideas why thus would be. It's our first MH so be kind lol
GJH
29,450
38,827
None, now sold
2006 to 2022
It could simply be a feature of the van. Some drainage pipes follow strange routes round items like fridges which can slow the flow down.
Just in case it is a blockage you could try using Buster Plughole Sanitiser Foaming Granules or even cheap cola as per Broken Link Removed from yesterday :)
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
[QUOT="laurieash, post: 1297556, member: 29917"]If the front of the van is higher than the back ie not level it will be slow.[/QUOTE]
Mine is a Autotrail 700 and pipe runs level with the top of the fridge so if the front of the van is higher the pipe runs up hill and water dont like that.
Mark5204
Mark5204
229
60
Bristol
Swift
Newbie
Thanks guys. Will make a point of checking level next time out. Also going to pour some cheap coke down sink too. Might clean it out a little
Phil J.
111
70
Clay Cross, Derbyshire
Autotrail Cheyenne 696
Newbie
How to Unclog A Drain With Baking Soda and Vinegar
  • Pour a pot of boiling hot water down your drain.
  • Dump in about 1/2 c. baking soda. Let that sit for a few minutes.
  • Then, pour a mixture of 1 c. vinegar and 1. c very hot water down on top of the baking soda.
  • Cover with a drain plug (to keep the reaction down below the drain surface) if you have one andlet it sit for 5-10 minutes.
  • Flush one more time with a pot of boiling water.
  • c=cup
  • worked in my shower
43,331
49,467
Half the problem is insufficiently sized pipes fitted by manufacturers to save a little space and money.
Water cant flow through a 20mm pipe like it can through a 38mm or 42mm as it does at home.
All my waste plumbing is the same as domestic.....38mm rigid with proper rigid bends and elbows.
flows the same as home.
Mark5204
Mark5204
229
60
Bristol
Swift
Newbie
Did you get it all converted?
Jul 29, 2013
9,071
18,539
Salisbury
Hymer B678DL A class
since 2011
I agree but I also think it's an Autotrail thing as well we are on our second one now and still the drains are slow I've tried all sorts but it only speeds up for a short while Bigger pipes required methinks.:groan:
pops
544
697
south glos
Pilote panel van
since1997
Mark, Our Kontiki 610 was slow to drain away in kitchen sink, but ok in shower and wash basin.
Mark5204
Mark5204
229
60
Bristol
Swift
Newbie
Thanks for the advice all. Really appreciate your help and support
Cossieg
221
98
Yate for the summer!
None now
Do you have a u bend thingy under the sink? Ours are always getting blocked in the kitchen and in the bathroom.
Mark5204
Mark5204
229
60
Bristol
Swift
Newbie
Hi yes we do. I poured 5 litres of coke cola into sink five hours ago and it still there. Something wrong somewhere I think
Badknee
7,408
412,824
notloB
Vantage Neo
Living the dream.
I get the wife to stand on a milk crate and blow down ours. (y) Any lips that can completely surround a Cadbury's Crème egg like a snake eating a rat, can cope extremely well with a 2" plug hole. :)
I take it from this post that Mrs Tootles doesn't read your posts or other than that you have a death wish. :LOL:
denisejoe
5,617
12,051
Warden isle of sheppy
Since 2004
the u-bend should have a piece at the bottom which you can take off and clean out. Ours just twists by hand anti-clockwise. Don't forget to bowl under it when you take it off! Always put a bit of vaseline around the seal before tightening.
joe
denisejoe
5,617
12,051
Since 2004
on our old van I used Mr Muscle drain unblocker as a final resort to clean the pipes and the shower waste which I couldn't get to. Left for an hour and then rinsed thoroughly.
joe
Mark5204
Mark5204
229
60
Bristol
Swift
Newbie
Tried all of the above still very slow :-(
