Sink drainage slow
Discussion in 'Tech/Mech General' started by Mark5204, Feb 10, 2015.
  1. Mark5204
    Mark5204 Read Only Funster
    Jan 20, 2015
    229
    60
    Bristol
    looking for advice. Filled kitchen sink today first time we have used it ourselves. When it came to draining water from sink it was stupidly slow. Any ideas why thus would be. It's our first MH so be kind lol
  2. laurieash
    laurieash Funster
    Jan 29, 2014
    596
    344
    HALIFAX
    If the front of the van is higher than the back ie not level it will be slow.
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,345
    34,929
    It could simply be a feature of the van. Some drainage pipes follow strange routes round items like fridges which can slow the flow down.
    Just in case it is a blockage you could try using Buster Plughole Sanitiser Foaming Granules or even cheap cola as per This Thread from yesterday :)
  4. laurieash
    laurieash Funster
    Jan 29, 2014
    596
    344
    HALIFAX
    [QUOT="laurieash, post: 1297556, member: 29917"]If the front of the van is higher than the back ie not level it will be slow.[/QUOTE]
    Mine is a Autotrail 700 and pipe runs level with the top of the fridge so if the front of the van is higher the pipe runs up hill and water dont like that.
  5. Mark5204
    Jan 20, 2015
    229
    60
    Bristol
    Thanks guys. Will make a point of checking level next time out. Also going to pour some cheap coke down sink too. Might clean it out a little
  6. Phil J.
    Phil J.
    Dec 21, 2014
    111
    69
    Clay Cross, Derbyshire
    How to Unclog A Drain With Baking Soda and Vinegar
    • Pour a pot of boiling hot water down your drain.
    • Dump in about 1/2 c. baking soda. Let that sit for a few minutes.
    • Then, pour a mixture of 1 c. vinegar and 1. c very hot water down on top of the baking soda.
    • Cover with a drain plug (to keep the reaction down below the drain surface) if you have one andlet it sit for 5-10 minutes.
    • Flush one more time with a pot of boiling water.
    • c=cup
    • worked in my shower
    • Like Like x 2
  7. Mark5204
    Jan 20, 2015
    229
    60
    Bristol
    Thank-you very much.. Very helpful
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,883
    17,542
    YO11 2BD
    Half the problem is insufficiently sized pipes fitted by manufacturers to save a little space and money.
    Water cant flow through a 20mm pipe like it can through a 38mm or 42mm as it does at home.
    All my waste plumbing is the same as domestic.....38mm rigid with proper rigid bends and elbows.
    flows the same as home.
    • Like Like x 1
  9. Mark5204
    Jan 20, 2015
    229
    60
    Bristol
    Did you get it all converted?
  10. Speve
    Speve Funster
    Jul 29, 2013
    2,089
    1,823
    Salisbury
    I agree but I also think it's an Autotrail thing as well we are on our second one now and still the drains are slow I've tried all sorts but it only speeds up for a short while Bigger pipes required methinks.:groan:
    • Like Like x 1
  11. pappajohn
    Aug 26, 2007
    29,883
    17,542
    YO11 2BD
    No, Americans do it right to start with. (y)
    I think its to do with volume.
    Small bore pipe will be completely full of water which will slow itself down.
    large bore pipe is water and air space so the flow isnt restricted by volume.
    • Like Like x 1
  12. pops
    pops Funster
    May 1, 2012
    419
    364
    south glos
    Mark, Our Kontiki 610 was slow to drain away in kitchen sink, but ok in shower and wash basin.
    • Like Like x 1
  13. Mark5204
    Jan 20, 2015
    229
    60
    Bristol
    Thanks for the advice all. Really appreciate your help and support
  14. Tootles
    Tootles Funster
    Sep 14, 2013
    9,134
    32,556
    Lancaster
    I get the wife to stand on a milk crate and blow down ours. (y) Any lips that can completely surround a Cadbury's Crème egg like a snake eating a rat, can cope extremely well with a 2" plug hole. :)
    • Like Like x 4
  15. Cossieg
    Cossieg Funster
    Jan 25, 2013
    201
    96
    Yate for the summer!
    Do you have a u bend thingy under the sink? Ours are always getting blocked in the kitchen and in the bathroom.
  16. Mark5204
    Jan 20, 2015
    229
    60
    Bristol
    Hi yes we do. I poured 5 litres of coke cola into sink five hours ago and it still there. Something wrong somewhere I think
  17. GJH
    Aug 20, 2007
    27,345
    34,929
    Definitely indicates investigating the U bend I think.
    • Like Like x 3
  18. Badknee
    Badknee Funster
    Aug 25, 2014
    3,728
    16,376
    notloB
    I take it from this post that Mrs Tootles doesn't read your posts or other than that you have a death wish. :LOL:
    • Like Like x 2
  19. denisejoe
    denisejoe Funster Life Member
    Aug 6, 2014
    1,216
    890
    Isle of Sheppy
    the u-bend should have a piece at the bottom which you can take off and clean out. Ours just twists by hand anti-clockwise. Don't forget to bowl under it when you take it off! Always put a bit of vaseline around the seal before tightening.
    joe
    • Like Like x 2
  20. denisejoe
    Aug 6, 2014
    1,216
    890
    Isle of Sheppy
    on our old van I used Mr Muscle drain unblocker as a final resort to clean the pipes and the shower waste which I couldn't get to. Left for an hour and then rinsed thoroughly.
    joe
    • Like Like x 1
