Silver screens leaking (1 Viewer)
kelv
672
895
leicester
Carthago 145
Now the weather is getting colder I have started using my silver screens the problem I have is when it rains they leak.
they hook over the driver and passenger doors on the outside leaking on the corners I think water is tracking around the elastic which is ment to trap between the rubber door seal hope this makes sense.
Any ideas on how to fix from fellow funsters
Nov 30, 2009
6,547
148,986
Pickering
PVC the PUG
We have silver screens and fiat cab. They don't leak. Do you mean into the hab. Or just water down the glass outside ?
Jul 26, 2010
664
904
Bristol
Hymer B584
since May 2010
I had the same problem during heavy rain. I think the water somehow channelled along the screens and poured through the passenger door.
Nov 30, 2009
6,547
148,986
Pickering
PVC the PUG
If that's the case , your doors can't be shutting properly. Surely ?
If waters leaking inside.
On ours there's a large silver corner , on the corner of the screen. This slips over the top corner of the door. Then you just shut the door .
There's no elastic.
Are they the proper silver screens from Cleckheaton ?
Ours have never leaked.
kelv
kelv
672
895
leicester
Carthago 145
Yes doing the same but both sides did you resolve it
kelv
kelv
672
895
leicester
Carthago 145
Purchased from brown hillsbrown hills
May 29, 2013
2,597
19,230
Tyneside
Chausson best of Flash 10
Several years now
Do people advise using silver screens over winter months ? Our MH will mostly be on the drive from end of Nov to April, bar a run every couple of weeks to turn the wheels.
What are the advantages of putting the silver screens on ?
Nov 30, 2009
6,547
148,986
Pickering
PVC the PUG
Oh, it's not the same as ours. Yours is a polar? If it's the same as on their website.
I don't know if that one fits the doors the same as ours.
Hope you get it sorted. Maybe give the door a good slam then get a hose pipe on it.
I'd be taking it back if it still happened. Say it's not fit for purpose. Raining in. Then get one of these.
http://www.silverscreens.co.uk/Contact us.html
kelv
kelv
672
895
leicester
Carthago 145
Only put screens on when I am using van to stop window condensation
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
It stops people looking inside to see if you have stuff worth nicking........I think.....(y)
kelv
kelv
672
895
leicester
Carthago 145
Techno 100 the elastic piece is only about 5mm wide I think it's to stop the plastic ripping when hooking over door corner
GJH
29,450
38,827
None, now sold
2006 to 2022
Ours are Taylor Made ones, purchased several years ago and no leaking in problems. As with others, they have no elastic but, rather, have a large silver corner (in two pieces which Velcro together) on the corner of the screen. That also slips over the top corner of the door before the door is shut.
As others have said, I should be taking them back if it were me.
GJH
29,450
38,827
None, now sold
2006 to 2022
We don't bother using them when the van is parked up on the drive, only when we are away in the cold weather, to stop condensation.
kelv
kelv
672
895
leicester
Carthago 145
Just been out to the van and checked the make is polar purchased from brown hills motorhomes and they do have an elastic bit
bobandjanie
8,161
15,796
Javea, Spain
Pilote V600g
Hi, we have silver screens and ours leaked, when we contact them it was because our motorhome has remis blinds fitted, so we needed to put a cut in the bit that hooks over door and made it bigger using Velcro. (n)
Problem solved. Bob.
kelv
kelv
672
895
leicester
Carthago 145
Sounds the same we have internal blinds not sure how to cut and VelcroVelcro
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
The silverscreen website details the three options of no blinds / blinds type A/ blinds type B
They re tailored mine for £30 http://www.silverscreens.co.uk/2010 Remis Blinds!.html
Terry
11,932
9,082
Lincolnshire
Can't remember ;)
Hi A few yrs back I found out by accident that if you don't put the flap bit so that the screen bit is on the outside below the door top it allowed the screens to let heavy rain into the top of the cab windows -hope you understand what I mean :)once fitted as described above they stopped dripping ;)
terry
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
I've heard of this happening and we had a minor leak on ours recently on a night of heavy rain.
I think the trick is to ensure the bit hooked over the door sits flat and has no creases in it. Also, it should not be under too much tension. These problems will stop the rubber seal working correctly.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Not a problem on coach built vans
kelv
kelv
672
895
leicester
Carthago 145
terry
I will have another look in the morning do not want to look at them tonight because guy Fawkes will be wearing them for a jacket
