WANTED Silver screen to fit 2015 Fiat Ducato (1 Viewer)
Christoph
554
758
Lytham
VW California
Since 2014
looking for a genuine silver screen to fit 2015 Fiat Ducato please.
Bluemooner
1,723
8,074
Ribble Valley
Dreamseeker Fifth Wheel
4 years
I have some but they fitted a 2013 model not sure if they are the same ones
Christoph
Christoph
554
758
Lytham
VW California
Since 2014
Hi, thanks for the reply. I think they need to be 2014 onwards to fit ours. Cheers
Wombles
10,808
11,132
SW England
A few years now
Don't know about the Paragon Silver Screens but the 2007 onwards Taylormade ones fit fit up to the latest model & it's only that the later ones allow for Remis blinds on the cab door inside section. Although the cabs have been "facelifted" on the front the windscreen section has not changed. If you have the Remis blinds you will either have to look out for ones that are already this type or consider inserting a piece of extra Velcro on the standard ones. We checked with Taylormade as we have some for sale http://www.motorhomefun.co.uk/forum...007-14-somerset-retrofestival-newbury.135374/ but ours are collect only from Somerset. Hope that info. helps :)
zac
2,606
1,858
Basingstoke
Rapido A CLass 10000
since 2013
They will need modifying, silver screens will modify them as it is on the sides that need doing, cant remember what i paid now but it wasnt a lot.
May be worth contacting them if it works out cheaper getting the 2013 ones and hvaing them modified.
Christoph
Christoph
554
758
Lytham
VW California
Since 2014
We've got the Remis blinds on ours so it looks like a new set will be the best option.
Wombles
10,808
11,132
SW England
A few years now
If you want Paragon then probably best idea as their cab internal sections are tight fitting if not ordered as Remis type so would need adjusting with Velcro & to get the right type secondhand would be unlikely. Lots of us on the forum rate Taylormade as equally as good a product ( we have these :)) & their recent cab internal fabric sections are more generous so often will fit over blinds plus later designs having split Velcro it just means adding another strip if needed. Taylormade cab internal corner section:
Hope the above info. is of use to any other Funsters with the same issue.
Puddleduck
12,386
44,003
Scottish Borders
Without at present
On and off for many years.
The internal thermal screens from our 2010 Ducato fit our new 2016 van if that helps anyone :)
