Sikaflex C Rail (1 Viewer)
The Whittys
48
6
Lincolnshire
Autotrail Imala 715
Newbie
Hi All
Thanks for all your advice on buying an awning. I now need to fit a C Rail to my van and Brownhills upped the price to £200 to bond it.
I've had advice from Magnum motorhomes to say I could do it myself with their parts. They have the rail and Sikaflex 512.
I know a cpl of people on here that have done this so wondering if i need to sand the area down or just bond it straight to the van. Oh i have an Autotrail Imala if that helps. Any advice appreciated.
Steve
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
Since 2004
I cleaned the area with methylated spirits that I had in the garage, put rail up to the van and marked where it was going to fit, sikafexed the rail and fitted it to where I had marked the van. I then dipped my finger in turps and smoothed the edges out, and the job looked better than professional.
John.
PS I got someone to help me put the rail up to the van roof.
The Whittys
The Whittys
48
6
Lincolnshire
Autotrail Imala 715
Newbie
Oh cool so no need to sand. Somebody said if i didn't sand it down it would just pull the lacquer and paint off.
Thank
43,329
49,446
Dont know for sure but i would think its coloured GRP/ABS construction, not paint and lacquer.
As said, clean off ALL traces of wax before glueing.
The Whittys
The Whittys
48
6
Lincolnshire
Autotrail Imala 715
Newbie
Hi all
Been looking at the correct way to use Sika and it says use a 2mm bead. Investigating further some people say that the bead you apply is thicker so when you press the rail on you get a constant 2mm thickness on all the rail.
Bit confusing cos if i put a 2mm bead and press flat not a lot will be left to bond. Any ideas?
Apr 14, 2008
860
3,706
Cromer norfolk
Bailey approach 745
since 2002
2mm constant thickness across entire width. I used a piece of tile spacer under brackets when I fitted our solar panel to give even thickness.
The Whittys
The Whittys
48
6
Lincolnshire
Autotrail Imala 715
Newbie
Ok so the rail will sit proud by 2mm?
