Shower wall small crack repair (1 Viewer)
fred flintstone
139
75
lincoln
Pilote P690
Since 2007 on and off
Does anyone know a way that I can fix a small (4cm) crack in the wall of my shower enclosure?
It doesn't leak but I am selling my motor home and want it to look better. Google has a lot of conflicting advice for this repair.
There are also a few scratches in the shower wall. Can these be tidied up with something like T-Cut or a similar product.
Any help appreciated.
andy63
4,672
15,018
south shields
None
since 1990
What sort of material lines the shower....
If it's plastic I would consider trying a weld using a soldering iron... if you can lay your hands on a little bit of plastic of same colour,and use a clean bit with the iron...
Had a go on the plastic skirt on the van and even though it's not brilliant it doe's seem secure now... with a bit practice I think I could make a better job...
It does require rubbing down but in places after rubbing down practically unnoticeable. ..
Andy.
fred flintstone
fred flintstone
139
75
lincoln
Pilote P690
Thanks for that.
It is plastic, I think :whistle:
I have seen a few where the scratches are removed with really fine wet and dry.
I will do a test patch first.
I will loan my in laws solder iron for the cracked piece, after practicing a lot.
