Shower and Basin Water Pump(s) (1 Viewer)
GettingBetter
5
Kent, UK
1992 Hymer B654
Novice
Just a quick question for any body that knows......where should I start looking for the shower and/or basin pumps, and are they switched by pressure?
I'd like to get running water, to aid cleaning of this project. :D
D
Deleted member 29692
There will only be one pump. It will probably be controlled by microswitches on each tap.
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Mine is in the water tank. There could be a screw off inspection cover.
I dangles on its wire into the water - give it a whack against the tank side - it might be stuck.
It looks like this - available here -http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2060353.m570.l2632.R2.TR2.TRC1.A0.H0.X12v+caravan+pump.TRS0&_nkw=12v+caravan+pump&_sacat=169486
scotjimland
2,335
10,111
A Woosh bang
in the water tank..:D
as said.. just one
unless it is a pressure system then the pump will be near the tank, perhaps under a bench or in a wardrobe .. it is controlled by pressure switch on the end of the pump
