Shoreline Power Rating (1 Viewer)
Aug 14, 2007
526
104
Devizes
Mobilvetta K-Yacht 80
Hi All,
Picked up the new RV from Travelworld RV yesterday.
Tried to plug the RV into the house this morning and it was continually blowing the house trip.
Worked out it is the transformer which is hidden away and appears to be the only manual I don't have. This would have been fitted by Travelworld RV when they imported it.
Does anyone have any idea what ampage rating the supply should be? I have always gone off a standard 13 amp socket in the utility room.
I do have a 30A supply to the hot tub so could get a spur off that.
Actually I may just have a new spur fitted to the outside of the house anyway. Will be putting a car port up to cover it. Got fed up having to continually clean the roof of the Winnie.
Will call Travelworld in the morning but good to hear from anyone who may have the answer.
Best regards
Chris
big map
4,597
182,269
Poole
Since 2009
Hi. you should have no problem running off a 13 amp socket (site hook ups are a max of 16 amps) try checking the rating of your house trip.
Mike.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Hi All,
Chris
This was done a couple of weeks ago. It's the current surge by the transformer, it was solved by one or two surge-guard type devices. Just search for THERMISTOR.
G2EWS
Aug 14, 2007
526
104
Devizes
Hi Mike,
Thanks for letting me know. The trip in the house is 80A, so I am beginning to wonder if something happened on the way home!
Hi Hilldweller,
Thanks for letting me know. I have posted a reply as Olley does not say if it worked or not.
I do reckon something else is wrong though. Maybe I will lift the board under the bed as I think that is where the transformer is tucked away.
Regards
Chris
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
try switching EVERYTHING off then re-setting house trip, if the power has only got to load the transformer I find it often works OK.
I never had this problem with the cheap yellow building site one, it only started when I replaced it with the "proper" thing !!!!
Good luck
Nigel & Pamala
Sundowners
3,289
3,571
37 years
10 amp. is what you will often get on campsites, so your system really needs to work on this supply.
Nigel
G2EWS
Aug 14, 2007
526
104
Devizes
Hmm lifted the board and it is not under there just lots of wiring.
I think the transformer is in the only outside locker I cannot get into because they put the old tv in it and that side is against a fence so cannot get the tv out!
Hi Nigel,
Yes my Winnie had a site transformer but the more heavy duty black one and I also had no problems.
If 10amps is the average rating I may be in trouble. Cannot do any more now as I will get in trouble! SWMBO is sorting Sunday roast!
I switched most things off and it was still doing it. I am going to Shrewsbury tomorrow so will call in to Travelworld on the way back and see what they say.
Have run a separate power line inside as I like to keep a couple of oil filled radiators running all the time.
Regards
Chris
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Chris
Speed of the trip is important. 80A is nothing for the odd ms, 'till your trip gets upset that is.
Academic if you can't use it on any site you visit.
MicknPat
614
3,606
Touring UK
39ft American A class RV
Since Oct 2007
Chris,
You don't say what year your RV is, our 2005 Discovery has a Xantrex Freedom 458 inverter / charger fitted.
When I plug the EHU into the mains the charger by default is on and if the house batteries are low can be charging at quite a large amperage..........I can only switch the charger off when connected, so make sure the fridge / freezer is off, also the engine block heater if fitted.
Hope this helps.:Smile:
Mick
G2EWS
Aug 14, 2007
526
104
Devizes
Hi All,
Thanks for additional info.
Everything is switched off and the only thing that causes the problem when being switched on is the transformer. Bit of a sod because I cannot get into the locker which has the old TV in. The locker is facing my fence so will have to wait until the weekend to drive it out and have a look.
Am also waiting for a call from Travelworld to see if they can shed light on it.
Regards
Chris
do1977
86
where i park up
A class rv
unplug every thing that is powered by the transrormer
there may be a ring main from the transrormer that may cause it
G2EWS
Aug 14, 2007
526
104
Devizes
Yep, like the sound of that thank you. Once I can get at the transformer I will see how easy that is.
Regards
Chris
G2EWS
Aug 14, 2007
526
104
Devizes
Just had a very long conversation with Simon the Service Director at Travelworld.
It seems that the problem is to do with the 110V to 240V smaller transformer that works the ring main. The system is already going through the 240V to 110V larger transformer and not tripping.
Once I get the TV out of the locker and check the transformer, if there is a problem they will send me a new one! Cannot ask for more than that. I am obviously happy to change it myself.
Best regards
Chris
Jul 29, 2007
6,551
39,656
Ipswich
RV and PVC
30 years
Hi Chris the 110v to 230v step-up tranny is only normally connected in to the genny, not the EHU.
Olley
G2EWS
Aug 14, 2007
526
104
Devizes
Fixed!
There is a 240 to 115 transformer that supplies the 115 items. This also goes to a 115 to 240 transformer that then supplies the ring main.
Spent a while going through the 240V circuit today and it seems the problem was caused by an after market mains polarity change over switch:
When I mentioned it to Simon at Travelworld he said 'remove it, they are rubbish!' and apologised that they should have removed it for me. It was fitted by the previous owner.
Now have electric working as it should do.
Yippee!
Regards
Chris
scotjimland
2,324
10,065
A Woosh bang
Chris
Nice when you find the problem.. glad your sorted :thumb:
I've always maintained that reverse polarity wasn't worth worrying about .. and in this case because someone worried it caused more problems than it was worth ... .. kinda ironic don't you think ... :Doh:
jim
G2EWS
Aug 14, 2007
526
104
Devizes
jim
Thanks Jim,
And you are right! Waste of time.
Regards
Chris
steles
240
61
Kent
Panel Van Conversion
Hi from confused
Why transform down to 115V and then back up to 230V for ring main, must be far more efficient to connect ring main direct to 240V supply with all necessary protection RCD and MCB?
Steles
scotjimland
2,324
10,065
A Woosh bang
Hi from confused
Steles
The smaller tranny , (110-230 v) is fed from the onboard genny not the 230 -110 tranny
When on EHU the 230v ring is fed direct as you describe.
jim
Jul 29, 2007
6,551
39,656
Ipswich
RV and PVC
30 years
Hi it is possible that some do transform down to 110v and then back to 230v so that the EMS (Energy Management System) fitted to many RV's works correctly, although I have never heard of any converter doing this.
Olley
G2EWS
Aug 14, 2007
526
104
Devizes
Whilst I cannot confirm, I believe that it is indeed wired to convert from 240 to 115 then converted from 115 to 240. I believe as Jim suggested it is all to do with the generator.
Regards
Chris
