semi air suspension (1 Viewer)
May 2, 2011
4
derbyshire
Since 2002
we have just had a semi air suspension system fitted which has improved the road handling I thought it would be good for when we use ferry.
We have had the tow ball bottom onto ramp when boarding so thought this would allow me to lift the rear to a height to clear the ramp.
After having it fitted I checked the distance it raised the rear when fully pumped up and found out it went up only 10mm which was very disappointing.
After speaking to my fitter he spoke to the manufacturer which is one of the main manufacturers they told him to alter the pump pressure from 3.5bar to 4 bar so this was done it made no difference has anyone had a similar problem if so what was the outcome.
Feb 24, 2013
13,083
101,452
Bolsover, Derbyshire
Hymer S800
not long enough
not what you want to hear, but ours lifts by over 100mm at rear and we regularly use it exactly as you planned to
we have a built in compressor and all controlled by keypad in cab area, how do you increase your pressure?
TheBig1
17,630
43,314
semi air, air bags dont always give a major height difference, it depends on a lot of factors. not least of which is the length of the rear overhang behind the wheels and the maximum suspension travel
the suspension type and geometry will limit what you can expect. All that semi air airbags do is firm up what is already there by replacing the bump stops
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Raise the pressure to the manufacturers limit - they're normally OK past 100psi / 6+bar.
Jul 29, 2013
9,071
18,539
Salisbury
Hymer B678DL A class
since 2011
We have semi air and it does not raise the back very much but when towing a trailer it does keep a level tow height rather than dropping with the added trailer nose weight.
Sep 26, 2013
4,170
5,156
Market Rasen
Self Build
Since 2003
When I replaced the spring asisters with the Dunlop kit the back end went up by 50mm before I even put any air in, and can ajust them by another 50mm with the air pressure.
RogerThat
1,128
991
North West
PVC
Agreed with @TheBig1 's point about overhang length.
Ours goes up +70mm at least (at 6bar max), I drive around on 2 bar as anything higher than that and the rear end gets very bouncy!
I'd also ask, are you compressor driven (with gauges)?
tonka
10,833
21,532
Cannock, Staffs
A class Burstner 800
Since 2000
My Autotrail has a long rear overhang and we had it bottom a few times..
£259 kit of ebay, DIY fitted.. (y) Sorted...
I never made any measurements but it's very visible the amount of lift we now have.
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Mine suggest 2 bar in normal running but I happily put in more if fully laden or go right up to the suggest maximum of 7 bar for a little extra lift on Greek ferries.
Oct 8, 2016
226
369
Tunbridge Wells
Bailey 75-2
I'm a newbie
I'm not an expert but I believe the gain in height when pump activated depends on what chassis you are running on. An ALKO chassis has torsion bar suspension and the vehicle when fully laden would only return to the original ride height of the unladen vehicle. The installation is different than that used on a CC or Peugeot chassis as these have leaf spring suspension and the air bellows sits on top of the spring and can raise the underside of the motorhome in relation to the axle (unlike an ALKO chassis). So more of a gain re ability to raise height if your motorhome has rear leaf springs. Both chassis types should additionally improve stability.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I have an Ebay kit on mine and it does rise a fair bit and enough for me to back into my second drive, without the air in I catch the towbar on the line of granite sets across the drive bottom. I put them up to 4.5 and it goes up about 1 1/2" more than springs alone. Make the filling fall out if I do not drop them on the road unless the garage is loaded right up.
Jul 23, 2012
80
82
Kingswinford & 86230
Burstner Elegance 890
Since 2012
Fitted air assist to the alko chassis on mine, raises the wheel arch by approx 100 mm - haven't measured what the back end goes up by.
I run mine ar 2 bar any more and the ride is too hard
Just a word of warning, lower the pressure before jacking the wheels up. I wanted to take the rear wheels off so pumped the system up to 6 bar to raise the chassis to make it easier to place the bottle jack underneath. As I then operated the jack handle to raise the wheels off the floor, one of the air bags blew off the lower fitting, I nearly filled my nappy!
Had to remove the lower fitting, smeared it with fairy liquid and located it over the air bag. Refitted the assy in place and re-pressurised the system, luckily no other damage done.
Dunlop system purchased from Marcel Leisure, very pleased with the result
Minxy
32,656
66,564
E Yorks
Carthago Compactline
We had AS semi-air suspension units put on the rear of a Rimor we had (7.24m) and it made quite a bit of difference to the height, before and after.
