Schaudt Electroblock EBL 271 (1 Viewer)
golly
2,006
69,617
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
Our Pilote G600 has the above fitted, this is the first van we have had with a Schaudt electroblock all our other vans have had Sargent units. Is there any way of switching off the battery charger while still having 240 volt plugged in (I keep the heating on frost guard) On the Sargent units there is a switch for the charger, but I can't see one on the Schaudt. Am I missing something simple here, (it doesn't take much):confused:
SandraL
1,373
985
Somerset
Hymer b694sl
If none then pull mains lead on front of ebl. Thats only way on our van.
Lenny HB
53,440
150,044
On the coast in West Sussex
Hymer B678 DL
The Elektroblock is fine to be left permanently on but if you really want to turn it off just pull the IEC mains plug out of the front of it.
DuxDeluxe
14,658
72,784
Planet Zog
A woosh bang van
since 2008
I have the same unit.... in the manual there is a diagram and I think you can either pull the appropriate fuse or disconnect the lead . I don't bother, to be honest
golly
golly
2,006
69,617
HYMERCAR PVC
since August 2009
Could be, why switch off the charger ?
There are two trains of thought re leaving on charge all of the time, was just wanting the option of having heating on frost guard without charger being on all of the time
FJmike
972
1,046
Swindon
over ten years
After looking into Schaudt Electroblock chargers and the way they work. I found out that they can give too much charge when on hook a long time, this can kill batterys especially Banners if not topped up regularly. (Thanks to AandN caravans for lots of sound advice).Since fitting two new Varta LFD batterys to my Pilote I now pull the kettle like plug out which means the mains power is still live to power a small heater.
Jun 6, 2012
1,141
1,545
Leeds
Since 2012
If you have a fused consumer unit then you should be able to isolate the EBL there. In my MH I have 4 fused isolator switches, EBL, 240v sockets, Alde boiler and Air con unit.
Oct 29, 2008
5,070
5,970
West Yorkshire
PVC
since 2008
NO Its not designed safe to be left permanently on according to Udo Land at Schaudt
Oct 29, 2008
5,070
5,970
West Yorkshire
PVC
since 2008
Don't see why not, it reduces to a maintenance voltage once the batteries are charged, no mention of it in either Schaudt or Hymer manuals.
Because they burn out. The manufacturer advised me about this when I emailed them. They get around £300 every time they rebuild one so that maybe why they dont say so in the manual. Udo Lang is their chief technician so I will take his word as correct.
Lenny HB
53,440
150,044
Hymer B678 DL
Not fit for purpose then, I rarely ever plug into EHU so not a problem for me.
Udo also told me the Gel setting was fine with Banner AGM batteries!!!
Oct 29, 2008
5,070
5,970
West Yorkshire
PVC
since 2008
Their argument is that they are not designed for permanent use. In my opinion they are either deliberately designed to fail, creating extra profit in repairs and replacements or they are indeed not entirely as you say "fit for purpose"
