Scalding hot water from shower. (2 Viewers)
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I have a Chausson which has a shower with a mixer tap on it, I am a bit scared of this because it is plainly dodgy . The valve is very difficult to set as the temperature varies from warm to bloody hot without touching it. Not the best thing to happen . What I need to know is there a proper thermostatically stable valve that I can fit, and where actually is the valve? I think it must be behind the plastic wall and would be major rip downs to get to unless there is another way or place to put it.
Any ideas????
ukbill
5,501
5,274
Pinoso
4 berth low profile
try turning down the stat for the boiler
GWAYGWAY
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I only has one hot water setting the thermostat is only the space heating
Dec 12, 2010
5,414
21,592
Cumbria
Don't think you can get a thermostatic valve for a camper, wonder if your mixer tap is a Reich model that you can access after removing the actuating handle and maybe change the ceramic cartridge, cost about a tenner off the internet ?
Apr 12, 2010
4,813
51,830
Bury St Edmunds, West Suffolk
Weinsberg Cara
since 2007
This happened to me recently. Made contact with the boiler manufacturer who put me onto a local agent. Couldnt have been more helpful, told me how to turn down the stat and all is well.
Phil
11,842
14,071
I have this problem in my Rapido but only when the heating is on. It's fine in the summer. It's not caused by the shower mixer but by the water pipes running through the same spaces as the heating ducts. This leads to local heating of parts of the pipes and the water in it, effectively meaning that the very hot water from the boiler is being diluted with water that is also hot intermittently resulting in scalding temperatures. The only answer I have found is to run the shower on cold only until it is actually cold, and then run the hot until its evenly hot. This wastes quite a lot of water though. I suppose I could do what someone suggested, collect the water and then tip it back in the tank.
GWAYGWAY
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I will stop washing for a month!!!!!!!!!
