Samsung galaxy Ace (1 Viewer)
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
In portugal at the moment had a Indian guy put me a local sim in so I could use as a hub works fine.
but cannot ring out.
tryed my own sim which is t mobile and that's the same.
tryed playing but not that technical.
Would go back to shop but to far down the coast now.
Answers very easy please and step by step as I say not very technical.
I would not also like to lose the use of the phone as my hub.
Cheers Laurie.
sedge
Jul 7, 2009
5,504
13,117
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Ha ha! My Ace went base over apex twice but not Pete's though we had them both at exactly the same time - when the phone wouldn't let me answer calls after a couple of months, so it went back to Virgin and came back again and was OK until quite recently. Then it did it again, but now out of contract so they've replaced them both FOC. We pay less too. I use mine much less than Pete, it's potty.
laurieash
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
It also aways says short of memory?
Lenny HB
53,448
150,064
On the coast in West Sussex
Hymer B678 DL
Used to have an Ace, never had any problems using abroad even used it in India.
Firstly was it brought as an unlocked phone or have you had it unlocked as I have had phones unlocked and found they don't always work with all sim.
The memory problem is easy to sort. When you delete text & emails they remain hidden in the memory there is a code that allows you to copy the dump files to the SD card, I used to have to do it every few months.
How to do it:
Dial *#9900#
Select Copy to SD
Warning only select copy to SD do not select any other commands.
Jun 2, 2010
4,924
11,290
Flintshire
Low profile
since 2010
How to do it:
Dial *#9900#
Select Copy to SD
Wife's HG phone kept coming up lack of memory, tried dumping every thing off it to no avail,with this knowledge probably would have sorted it but without secret codes got shut and bought a decent easy to use iPhone.
Aug 18, 2014
23,786
133,731
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Cheers Laurie.
Have you used it abroad before? I.E. is the 'phone roaming ' turned on. If it isn't , it has to be done before you leave country of sim card , then it wont work on your card.
Would have thought it would work on the local card. Assuming as other poster said that it is unlocked to any provider.
laurieash
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
Memory problems sorted thanks lenny,
just need to sort dialing out problems.
laurieash
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
[Yes it is a unlocked phone had o2, tmobile also3 didn't put on roam before I left the uk.
