Roof Vent Fan (1 Viewer)
Feb 22, 2011
9,801
20,209
Newcastle under Lyme
Hymer B544 A Class
I`ve been having a poke around the Hymer getting to know things and what they do and today I took a look at the ceiling vent fan in the kitchen area.
It seems to work either blowing in or extracting depending on which way the switch is set and the roof vent is motorised.
However when I`d cleaned the fly screens and fan blade the roof vent would not close.
I removed the motor which is attached to a gear arrangement and it`s working but only seems to want to open the vent and not close it. I closed the vent manually, reassembled it and the motor opened it again when switched on !
Does anyone know what should activate it to close or if it`s kerput a source for replacement motors ?
It`s not overly important, in fact I doubt I`ll ever use it but I do like things to work.
Cheers,
M
Madwife
Hope you can get it working as these are great fans. Ours has the manual gearing so cannot help with yours. However have you tried switching the thermostat to hot as that gets the fan in ours to stop
Kath
18,038
48,155
Surprised you say you don't use it. Don't you cook in the MH? A fan is very useful for removing cooking smells and in cold weather will reduce condensation by drawing away the steam from pans.
2,356
10,237
Had one in a previous van, yes it does all that DBK says.. but we found it noisy, so removed and fitted a roof light..
53,496
150,316
Agree brilliant bit of kit, also when you come back to a hot van great for cooling it down in minutes, wouldn't be without it, worth every cent of the €450 it cost as an extra. Yes it is a bit noisy but you can't shift air in reasonable volumes without noise can't blame the fan for that.
2,356
10,237
I just open the roof light and windows.. plenty of draft
and it's a noisy fan compared to most desk fans that are almost silent.. sounds like a helicopter in the van
Nov 30, 2009
6,548
149,069
Pickering
PVC the PUG
Ralph has fitted one to Pug. There's a manual twist knob on ours too. To make the lid come down. It also closes automatically , if it rains. We noticed , if you open a window in the back , turn the fan on. It really pulls the air through the window. Very powerful. He's put ours behind the cab seats in the kitchen area. That way all the cooking smells will be sucked out. The loos down that end too. So if the sog doesn't do its job the fan will !
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
I have 2 fully auto ones on my RV and have specified them on the new Flair. They are great and have lifetime warranty. Unfortunatly the company has been taken over and some US forum posters have commented on their being some issue on thier level of warranty. However if you have a failed part I would call Fantastic in the US and see what they say. They may not want to stump up the UK carriage, but you can only see. And as another poster has acknowledged there is a UK dealer, however my discussion with him was not too rewarding as he seems to buy in a container load once a year. But still worth a call.
Figaro
Feb 22, 2011
9,801
20,209
Hymer B544 A Class
Thanks guys for all the useful replies. I`ve only had the Hymer for a few weeks and not done much cooking in it yet, nor have we experienced any hot weather :(
In view of most rating it as a useful fan, I`ll do my best to get it working properly and try and use it when Summer arrives (y)
Thanks again
Figaro
Feb 22, 2011
9,801
20,209
Hymer B544 A Class
Kath[/QUOTE]
Thanks for the advice, btw what does the thermostat actually do ? there doesn`t seem to be any heating element but it must control something
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
The thermostat will bring the fan into action when the internal temperature in the avn is higher than that set on the thermostat. Have a read through the descriptions on the web site I linked to in my earlier post above.
M
Madwife
As Jean Luc says the thermostat relates to the temperature inside the mh. We have found the fans very useful as really does suck the air out. The one in the shower area great for keeping condensation at a minimum when you are using the shower.
Kath
Figaro
Feb 22, 2011
9,801
20,209
Hymer B544 A Class
Ah yes, turned the thermostat and it closed (y)
It seems like quite a useful function, to be able to set it so if the van gets hot it will open and blow out all the hot air then close again when cooler or it rains !
I think I will be able to use that when we get some summer weather.
Thanks again for all the useful posts:)
Sep 9, 2011
1,010
6,767
Worcester
looking
I removed mine and put a rooflight in because it made the kitchen much lighter its up for sale in classified
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
We use ours as alternates to AC, set it extracting on a thermostat setting, open windows on cool side of MH and it creates a cooling breeze.
