I would have to go up from the bottom with an unblocker wire mine are at the back of the MH, on the roof it looks like what you see in your bathroom sink when you pull the plug out, round metal with holes in it, i have sent for some modeling mesh its very fine that should sort it out up top tape that over it then none can go downMy Sundance has them, drain holes either side just behind the high top.
I use a drain unblocker wire, available from most hardware stores. Looks like a length of steel coiled wire. I will try to get a link for you. They are usually used for sticking down a domestic u-bend to clear a blockage, but push out pine needles just as well.
