roof box (1 Viewer)
frosty
26
worthing
motor home
hello can any one help please,i dont have a roof rack and cant realy afford one,so was thinking of screwing my flamma box to the roof?i am worried about doing this,but i understand that flamma do a fiting kit that screws on to the roof and they say you dont even have to use mastic to seal the screw?the box i have is a flamma ultra 3, other than water getting in to the roof im worried about the size screws to use?any advice would be very helpfull,regards si frosty, my motorhome is a CI
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Personaly I would NEVER screw anything to the roof,with the constant movement its only a matter of time before you get water ingress.If you must have the extra storage go for a backbox,its much easier to get in and out of without always climbing on the roof.
bigfish
348
84
Eastleigh, Hants
8 years, but had caravans & Tents before that
We bought a van with a roof box allready on, left it for 2 trips then got rid of it and noticed the difference straight away in performance / fuel economy both much better without it. put the box on the back if you have to but deffinately not worth putting on the roof.
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Hi Frosty, ours is stuck and screwed :thumb: never screw anything to your van without sealing it :thumb: The back box would get my vote :thumb: if possible, if only because the roof-box knocked 4 mpg off (used to get 31 mpg now only 27 mpg less 10mph off top speed :cry:)
terry
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Hi Frosty,
As you are in Worthing why not drop by one weekday and ask Glenn or Ian for some advice, we have roof rails for Fiamma boxes etc.
Peter
scottie58
60
18
berks
just put my Omnistor carry all 150 rear box in the classifieds!:Smile: PM me if interested
haganap
12,762
26,458
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
No sealant? not a chance. for a few quid for a tube I would deffinately use it. You can use a fitting kit without rails though.
F
frosty
26
worthing
motor home
thanks for replys,i have been reading the thread about fixing solar panals to the roof and some are saying to use sikaflex512 ? do you think sikaflex is strong enough to stick my box brackets,then bolt the box to the brackets?or when im doing 60mph will the box be landing on the bonnet of the car behind me,regards frosty
haganap
12,762
26,458
planet earth
I have silkafex 512 holding my dome on. I was really nervous about it but, touch wood it seems ok. However a top box would weigh more and especially when its loaded.
if you give it a try, let me know so I dont follow you.:ROFLMAO:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
I have 3 solar panels with the brackets stuck down with Sikaflex and they have been up there for a few years now with no problem.
I think a topbox would have more turbulance,so would not risk it.
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Hi Frosty, you will need to screw / bolt as well as stick :thumb: Sikaflex does not stay stuck to plastic :Eeek: In deed most leaks occur when plastic meets ali panels or roof lights.To get over this on my self build I used both Sikaflex (to stick ) and GP Mastic to stay sealed. :thumb: By the time the sikaflex gives up (may be a couple of years down the line :ROFLMAO: ) the GP mastic will still seal the job and quite a bit of force is needed to lift either roof box or sky lights :thumb:
You can buy ali sheets quite reasonably priced and stick a large sheet over any holes made after taking the roof box off :thumb: stick straight on top of existing roof ,it will also help strengthen it :thumb:
terry
