rocket wi fi
Discussion in 'Computers' started by Welsh girl, Jul 6, 2011.
  1. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,711
    1,316
    living the dream.
    I have just had the rocket wi fi hi power outdoor USB adaptor delivered and after some hassle getting the drivers to work, windows 7 didn't recognise the driver, got compatibility assistance to get it working but it still is making no difference to my signal, what are you supposed to see, the signal meter is showing exactly the same as before and it hasn't shown up any more wi fi than I had already??
    The shortcut icon on the desktop just brings up the the words " realtek wireless LAN configuration utility Realtek semiconductor corp, copyright (c) 2003 to 2007", with the numbers RTL81.
    Am I doing something wrong, can anyone help on this?
  2. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    Are you on a laptop
    are you on wifi now
    look at the bottom to find your wifi signals
    look for another small icon looking like a Vdu may be flashing
    look were it shows all secured and unsecured in range
    see if it shows all the same as you would normally have, but with another name..maybe a 3 or a 5 on the end of it...it may even look as if is showing less strength than the normal one that will be ok
  3. hilldweller
    Dec 5, 2008
    27,253
    26,256
    Macclesfield
    Make sure your built in WiFi is turned off.
  4. MrMotorhome
    MrMotorhome Read Only Funster
    May 19, 2009
    640
    1,128
    wi fi
    Check the adapter is 'enabled' :Smile:
    Andrew
  5. 1948
    1948 Read Only Funster
    Dec 3, 2009
    444
    46
    surrey
    hi
    try turn off the internal wifi, to be sure it is off , open web browser and you should have no connection
    then connect the rocket wifi to computer, and open the applicaion. if you get internet connection then you know for sure it is working
  6. Welsh girl
    Nov 7, 2009
    2,711
    1,316
    living the dream.
    Thanks for the reply guys, I have tried all the above and still nothing, it is "enabled" and there is no VDU flashing, I have turned off my inbuilt wi fi but nothing shows.
    Just 3 three connections showing with inbuilt wi fi turned on and nothing with wi fi off, even though the rocket is "enabled" and I am on a laptop.
    I have now emailed the supplier with a screen shot to show them what is happening, perhaps it just wont work on win7, just have to wait for them to get back to me now
  7. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    I got one during the week and it picked up 7 secured connections all around me in a rural area.
    A couple of them were BT hubs that offered me access for a price.
    Quite impressed with it really though there are a lot of potential configurations and setting I will have to get to grips with.
    How many users have found the can piggy back onto unsecured routers on the continent..........for emails etc.
    If you have 3 connections showing select 1 preferabley your own from a distance and see if it connects> ..I just put my password in and there I was connected from over 100 yds away no prob.
    Could not connect to others that were secured and Im not computer savvy enough to crack them
    barry
  8. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,838
    3,339
    Eastbourne East Sussex
    It might just be that you've got a duff one.
  9. activecampers
    activecampers Read Only Funster
    Jul 28, 2008
    420
    102
    Heathrow
    The rockets do work, and do work well, but my dad has had a faulty one.
    SOme laptops stick the rocket into power save which can confuse it, and more than once I've had to remove it from device manager and plug it in again. WIndows 7 should detect and install core drivers.
    My suggestions:-
    - plug it into a different USB port
    - Bring up a command prompt, and type NETSH WLAN SHOW NET - and this will either give you a list of networks or tell you that the rocket is powered off
    - Go into device manager, and expand network adapters, and remove it from there (it will be the RTLxxxx one). (It will only appear in there if its plugged in* - so plug it in before removal)
    * OK not true, for the geek wannabies bring up an admin command prompt, type SET DEVMGR_SHOW_NONPRESENT_DEVICES=1 then DEVMGMT.MSC then VIEW-->HIDDEN DEVICES and you can see older and non present devices and remove them and any historic junk. Be waery though...
  10. Welsh girl
    Nov 7, 2009
    2,711
    1,316
    living the dream.
    Richard at facultyx couldn't be more helpful, windows was blocking the email attachment as it deemed it to be potentially unsafe.
    He sent me another email (5 in all) with windows 7 driver and now its working great thanks for all the advice guys.:thumb:
    Got less now than with my inbuilt one but never mind will be better when I use it further away from the source.
  11. hilldweller
    Dec 5, 2008
    27,253
    26,256
    Macclesfield
    I can't work that one out.
    Prove your theory, go for a walk.
Similar Threads
  1. Traveller_HA5_3DOM
    5
    347
