Reversing light not working. (1 Viewer)
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
On checking the van prior to its mot I discovered the reversing light isn't working. Bulb is fine and I wasn't sure which fuse but F31-F35 are ok. so this points to reversing light switch. Managed to get one from gsf. I'm lead to believe that the switch is top left of the gearbox and can be accessed by removing the air box (3.0 x250)?
Can anyone assist please.
Dec 6, 2011
385
458
West Wales
Ducato Van Conversion
Since 2011
It is fairly easy to do. As you look at the front of the motor it is on the front of the gearbox about a third of the way down. Remove the top of the air filter container, remove the air filter and you can look over the top of the container and see the switch. you may find the spanner size is different between old and new.
Mike
Aug 18, 2014
23,782
133,686
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
I changed mine on an older one the other day & it is quite easy with the air intake out of the way but I'd also check that it isn't just the connectors need cleaning & reftting.
GJH
29,450
38,827
None, now sold
2006 to 2022
Before undertaking a bigger job, have you checked that the bulb is contacting properly? Our reverse light wasn't working and the cause was minor corrosion, easily sorted out with a bit of emery paper.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
It's NOT a Testable item, Just in case you thought it was ;)
sdc77
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
The light clusters at the back are cheap and nasty things but yes thanks I checked
OMG .... you're joking... I never knew and cancelled the mot to sort it
Arrrrgh
:Eeek::pray::swear2:
(Thanks)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Just leave it, and get the wife to walk behind you with a torch. Much cheaper, and you get to laugh. (y)
May 23, 2012
373
342
Anglesey
Rapido 666f
Check the bulb and connections again 99% its that
Mar 23, 2012
9,546
32,096
sleights
c class
Put a meter from the wire to a good earth should show a bit more where the problem is
