Reversing camera (1 Viewer)
reenag06
70
14
cheshire
Autocruise starspirit
I'm a newbie
I have just bought an autocruise starspirit and want to have a wired reversing camera installed. Is this easy to do? Does anyone know anyone who could install one in the Cheshire area? Would a wireless one work ok?
DuxDeluxe
14,658
72,784
Planet Zog
A woosh bang van
since 2008
Hi, some people have found that wireless cameras are prone to signal fade and interference, so a wired one is the best option. Dave Newell leisure services or Phil McNally from Rhinoinstalls might be worth a look. Phil does mobile fitting
scotjimland
2,335
10,105
A Woosh bang
As David said.. forget the wireless.. they are just about ok in cars with a short distance between the camera and monitor..and while the RF signal is 'wireless' the camera still needs a wire ran from the cab to provide the 12vdc so no real saving in labour. Wired is more reliable and won't suffer interference.
You also have to decide if you want it switched 'on' when you select reverse gear or not.
It's a relatively easy but time consuming job, the cable can be routed either along the chassis rail, or inside through lockers, sometimes utilizing existing cable routes. ..
My preference is along the chassis rail.. I've installed two that way, but it can be dirty and awkward without a proper car ramp or pit. Inside takes more time to do a neat job.
reenag06
reenag06
70
14
cheshire
I'm a newbie
Thanks guys, will def go for wired version and think dashboard mounted. Just need to find installer and will take a look at the two mentioned.
trekkin
332
490
Staffordshire
Rv
5 years but still learning
Hi just had a four camera system fitted ( two reverse, one back down the road,one down to the bumper, and one side left one side right by indicator repeaters) ,not massively more than a single, and gives clear view all around. Multiple or single view selectable on monitor via remote, works well
As the saying goes "you only fit them once so fit the best" you can
Adrian
