Reversing camera (1 Viewer)
Nov 2, 2014
1,086
1,012
somerset
coachbuilt
Hi guys my reversing camera clips on to rear view interior mirror, but the rear view mirror keeps falling down any ideas on instant contact adhesive but ite not a big area thanks in advance steve
Howard H
4,832
4,795
West Lancashire
Benimar mileo 294
Can't tell you what to use but I can tell what not to use super glue it will crack the windscreen I was told not to use it for that reason but ignored the advice and yes the screen cracked
DuxDeluxe
14,658
72,783
Planet Zog
A woosh bang van
since 2008
There is a special glue specifically for glass, which worked for me with my dash cam mount
Jun 29, 2015
3,479
57,446
Southampton
caravan (for now)
on and off since 1984
I had the same problem on the one I have there are slots in the monitor I have cable tied it to the mirror. Been OK for years.
Jan 23, 2016
1,890
305,377
Wales
Adria Coral 660SP
25 years
Ask an Autoglass fitter, or take MH to their depot.
They are gluing mirrors to windscreens day in, day out.
TheBig1
17,630
43,280
The stuff used by autoglass is 2 part. First you clean both halves with alcohol wipes then a layer of glue and a small mesh pad. It really does work well so get it right first time
43,330
49,446
Providing you follow the instructions to the letter i guarantee this WILL work and will stay stuck for years.
<<<<<Broken Link Removed>>>>>
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I use a monitor intended for mirror mounting. If yours is the same you could do as I've done and remove the mirror head & mount the monitor on the mirror stalk. The monitor becomes a mirror if the camera is switched off - saves weight on the glue patch. In my case the mirror only ever gave me a view of the kitchen so the camera is on full time.
Jan 23, 2016
1,890
305,377
Wales
Adria Coral 660SP
25 years
Lying in the sauna this morning, where my best thoughts occur, whatever glue that original manufacturers use or companies like Autoglass, they can obviously easily remove the mirror bracket when required, how I don't know but it need consideration because if you need a windscreen replacement and the glue you use cannot be 'broken' you will lose your mirror mount and your camera screen, until you get a replacement.
